La classe à l'état pur. Grande qualité et efficacité. Silencieuse, ne chauffe pas, ou pratiquement pas, les 12v sont régulés au 10eme de volt et fourni avec 2 câbles de bonne qualité, dc 2.5mm et 2.1 mm.
By buying this product you get 31 loyalty points
The LPS80 Dual LHY Audio linear power supply is a low-noise power supply based on the use of a high quality custom toroidal transformer, four high-performance LT3086 regulators, high-current, low-resistance Schottky rectifiers, and Vishay BC electrolytic capacitors, all mounted on a four-layer PCB with gold-plated copper circuits. This power supply is capable of delivering 12V DC 3A + 12V DC 3A simultaneously and without interference, allowing it to power multiple HiFi devices. The output is protected against short circuits and overcurrent.
| 1 | Power button |
| 2 | Display |
| 3 | DC outputs on GX16 connectors |
| 4 | 220-240V AC mains input |
Technical Specifications
| Specifications | |
| Product type | Power supply |
| Output voltages | 2x 12V DC 3A |
| Outputs | 2x GX16 2-pin connectors |
| Regulators | 4x LT3086 (80W) |
| Output voltage accuracy | ±2% |
| Load regulation | ±2% |
| No-load noise | < 50μV |
| Noise under load | < 50μV |
| Power supply rejection ratio (PSRR) | 80dB (120Hz) |
| Overcurrent protection | 105% to 130% |
| General | |
| Power supply | 220-240V AC 50/60Hz |
| Dimensions | 250 x 130 x 60mm |
| Weight | 2.1kg |
| Color | Black |
| Package contents | 1x LHY Audio LPS80 1x OFC Copper GX16 to DC jack 5.5/2.1 power cable 1x OFC Copper GX16 to DC jack 5.5/2.5 power cable 1x AC power cable |
| Input | IEC C14 |
| Output | GX16 |
| Color | Black |
| Output voltage (V) | 12.0 |
| Output current (A) | 3.0 |
| Input voltage (V) | 240.0 |
| Input voltage (V) | 220.0 |
| Power Supply | Regulated Linear Power Supply |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Hocine H.
