LPSU200 HiFi Linear Supply High Fidelity 12V + 5V 6.5A 150W NAS / Freebox / Squeezebox
Reference : 13387
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 05-05-2026.
LPSU200 Linear power supply ReGulated
12V + 5V 6.5A / Filtre EMI
Audiophonics is proud to present you this regulated linera power supply designed to provide clean power to your network players, storage peripherals, small audio devices...etc. This power supply has two GX16 output (avionics type) that can be locked. One is delivering 12V and the other 5V with 5A load. A cable GX16 to Jack DC 5.5/2.5mm is included with the device.
Quality components are integrated in a robust 100% Aluminum housing for increased durability and reliability. This LPSU is thus among the best value for money on the market.
EMI Filter
Equipped with an efficient EMI filter eliminating noise, this audiophile 6.5A power supply is specially designed for devices such as a NAS, an Internet Box, a Mac Mini, a DAC, a Squeeze box or a Docking station.
Audiophonics alimentation linaire régulier gx16
The GX16 to DC 5.5/2.5mm jack cables needed to use the power supply outputs are included.
The positive is located in the center of the Jack DC connector.
SpEcifications
Product typeRegulated linear power supply
Input voltageAC 220V
Output voltage / intensity12V + 5V (6.5A)
Transformer160 VA
Input ConnectorIEC C14
Output connectors2x gx16 2 pôles
Cable gx16 to Jack DC 5.5/2.5mmIncluded
Center Pin Postive
Dimensions257x212x70mm
Poids5.5kg
Brushed aluminum
Included parts
Cable gx16 2 poles 1.5mx2
Power cablex1
InputIEC C14
OutputGX16
ColorSilver
Output voltage (V)5.0
Output voltage (V)12.0
Output current (A)6.5
Input voltage (V)230.0
Power SupplyLinear
3 reviews
Mawels
Très belle construction, assez lourd, beau produit.
Alimente mon décodeur Orange + switch audiophile Silent Bonn 8
Alimentation silencieuse, ne chauffe pas.
Un petit palier de franchi sur la qualité : apporte un peu plus de relief et de stabilité à l'image (écran LCD 4K), plus de clarté et de détail dans le son.
Me permet d'alimenter deux produits en même temps.
Rien à dire pour le prix.
This review has been posted for LPSU200 HiFi Linear Supply High Fidelity 12V + 5V 6.5A 150W NAS / Freebox / Squeezebox
Really good PSU (build and weight), using it to supply clean power to the Node 2i on the 5V rail and nearby router on the 12V one. Can not comment purely on the PSU but both the upgrade board on the Node with the power supply deliver a superior sound. More clarity, realism and surprisingly better bass weight. Definitely worth it, a quite considerable upgrade.
Thanks Audiophonics team!
Service toujours impeccable de la part de Audiophonics
Alimentation achetée pour un petit streamer et mon décodeur TV Orange.
sur le premier un bon en avant sur la sortie optique, gros gain en définition et bande passante, étonnant qu'un petit streamer à 100e puisse sonner aussi bien quand il est alimenté correctement.
Sur le décodeur TV, la sur la partie son, c'est le jour et la nuit, Audible sur les hp de la télé, mais branché sur mon dac le gain est énorme, et on s'aperçoit que les sources télé ne sont pas si mauvaises. Un gain aussi sur l'image mais moins flagrant.
Donc super content de l'achat, très bonne alimentation pour un prix raisonnable.
