The Topping Hynotone CAB105 is a 1-way passive guitar speaker in an ultra-compact format, designed to pair with a power amplifier or a guitar head. It features a high-performance 5-inch driver mounted in an optimized enclosure, capable of handling up to 50W at 4 ohms, delivering a dynamic response and a sound level suitable for both practice and small stages. Its connectivity is based on a 6.35mm (TS) jack input, allowing direct connection to an amplifier. Thanks to its specific acoustic design, it delivers a surprisingly full sound for its size, with a tonal signature tailored for electric guitar. Compact (approx. 250 x 120 x 174 mm) and lightweight (~2.15 kg), it easily integrates into a pedalboard or a portable setup, making it an ideal solution when paired with a compact power amplifier such as a pedal-format model.
Despite its small size and single 5-inch driver, the CAB105 has been designed to reproduce the feel of a much larger cabinet. Thanks to specific tuning of both the driver and the enclosure, it delivers a rich and dense sound reminiscent of 2x12 or 4x12 configurations in a minimalist format.
This approach makes it particularly suitable for guitarists seeking a “big amp” sound in a limited space, especially for home practice.
The CAB105 features a 5-inch guitar speaker capable of handling 50W at 4Ω, offering excellent dynamic response and solid power handling.
This type of configuration provides precise sound with good attack and a response well suited to dynamic playing, while remaining compatible with modern compact amplifiers.
Thanks to its compact size and ease of use, the CAB105 integrates perfectly into modern setups:
It therefore represents a lightweight alternative to traditional cabinets, particularly suited to portable setups and minimalist configurations.
Technical specifications
| Specifications | |
| Product type | Passive speaker |
| Driver | 5" |
| Input | 6.35mm TS jack |
| Power handling | 50W |
| Input impedance | 4 ohm |
| General | |
| Dimensions | 250 x 120 x 174mm |
| Weight | 2.155kg |
| Package contents | 1x Topping Hynotone CAB105 |
| Color | Black |
| Impedance (Ω) | 4 |
| Efficiency / Sensitivity (dB) | N/A |
| Lowest frequency (Hz) | N/A |
| Highest frequency (Hz) | N/A |
| Power (W) | 50.0 |
| Number of ways | 1 |
| Number of loudspeakers | 1 |
| Speaker type | Passive |
| Speaker form factor | Other |
