High Purity Silver Plated OFC Copper Wiring Cable PTFE Sleeve 0.5mm² Ø 3mm Transparent
This cable wire incorporates a high-purity OFC Copper conductor with a cross-section of 0.5mm² with Silver plating, ensuring excellent conductivity while being resistant to oxidation.
4.5 / 5
Reference : 13492
2,90 €tax incl.
2,42 € tax excl.
Shipping date: 06-05-2026.
Câble au mètre
Fil de câblage
Fil de Câblage Cuivre OFC Haute Pureté Plaquage Argent Gaine PTFE 0.5mm² Ø 3mm
This cable wire incorporates a high-purity OFC Copper conductor with a cross-section of 0.5mm² with Silver plating, ensuring excellent conductivity while being resistant to oxidation. The conductor is covered with a transparent PTFE insulating sheath for an external diameter of 3mm. This cable will allow you to carry out the internal wiring of your DIY devices and projects.
Product typeWiring cable
Conductor materialOFC Copper
Conductor section0.5mm²
Conductor platingSilver
Sleeve materialPTFE
Cable diameter3mm
Min / Max temperature-65°C / +200°C
Sleeve colorTransparent
QuantitySold per meter
Diameter (mm)3.0
Length (m)Sold by length
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)0.50
Ground / ShieldingNo
2 reviews
Perfect wire with strong isolation
I use this wire for many thing, from cables, to internal wiring, and etc. Always perfect. Isolation is quite fat and strong, what sometime hel, sometime been hard. But it work perfect. Wire by him self is perfect. Recommend!
This review has been posted for High Purity Silver Plated OFC Copper Wiring Cable PTFE Sleeve 0.5mm² Ø 3mm Transparent
Good wire
Good wire, great price, just i guess is more thin than have to be, teflon isolation is hard to put out /i has to fire it only/, and very fragile /is silver/. But sound is perfect.
This cable wire incorporates a high-purity OFC Copper conductor with a cross-section of 0.5mm² with Silver plating, ensuring excellent...
