7HZ x CRINACLE ZERO: 3 In-Ear Monitors IEM Silver
New
The 7Hz x Crinacle ZERO:3 are wired in-ear monitors with a 10 mm dynamic driver, designed around a composite diaphragm with a metal dome. Combined with an N52 magnet and a CCAW voice coil, this driver aims to extend the bass response and improve responsiveness while limiting distortion.
Reference : 22664
34,99 €tax incl.
29,16 € tax excl.
7Hz x Crinacle ZERO:3 Dynamic In-Ear Monitors IEM 105dB 30 Ohm 10Hz-20kHz 3.5mm Jack Mic Silver
7HZ x CRINACLE ZERO 3: Front view
Developed jointly by Crinacle and 7Hz according to the characteristics of the JM-1 curve, they seek a natural tonal balance and a structured soundstage. Their ergonomic shell and detachable cable with 0.78mm 2-pin connectors make them suited to everyday listening, with the option of replacing the cable with a compatible model.
7Hz x Crinacle ZERO:3: Dynamic driver with composite diaphragm
The 7Hz x Crinacle ZERO:3 are based on a 10mm dynamic driver fitted with a composite diaphragm with a metal dome, designed to combine rigidity and low mass. The dome helps extend the frequency response, while the composite suspension supports its movement to better control the excursion of the membrane. This architecture aims to strengthen bass extension while limiting distortion, with the goal of preserving detail clarity when the signal becomes denser.
7Hz x Crinacle ZERO:3: High-efficiency magnetic circuit
The driver relies on an N52 magnet and a CCAW voice coil, whose combination improves the efficiency of the electromagnetic motor. The membrane can thus react more quickly to signal variations, which favors the reproduction of transients and the precision of attacks. This design complements the work of the diaphragm: it aims to maintain a controlled response, both on bass impacts and on rapid dynamic changes.
7Hz x Crinacle ZERO:3: Tuned by Crinacle and 7Hz
The response of the Zero 3 was defined jointly by Crinacle and 7Hz, following the characteristics of the JM-1 curve. This choice aims for a natural tonal balance, without isolating the reproduction of bass, mids and treble from one another. The tuning also seeks to organize the soundstage, in order to distinguish the elements of the mix more clearly when listening to music or watching content.
7Hz x Crinacle ZERO:3: Ergonomic shell and materials
The shell, newly molded around the contours of the ear, is designed to improve fit and distribute contact more comfortably during extended listening sessions. Its front part uses an eco-friendly medical-grade plastic, complemented structurally by the aluminum alloy back plate. This combination pairs contact suited to in-ear use with a construction designed for daily wear.
7Hz x Crinacle ZERO:3: Oxygen-free copper cable
The ZERO:3 come with a high-purity oxygen-free copper cable, connected to the earphones via 0.78mm 2-pin connectors. This detachable interface makes it easy to replace the cable in case of wear or to swap it for a compatible model, while the conductor provides the electrical connection to the driver. This allows you to keep the earphones while changing their connection according to the needs of your setup.
Technical specifications
Product typeIn-ear monitors
Frequency response10Hz-20kHz
Impedance30Ω
Sensitivity105dB
Total harmonic distortion (THD)0.5%
Drivers1x Dynamic Ø10mm
Cable termination3.5mm Jack
Earphone connectorsCIEM 0.78mm 2 pins
Cable conductor materialOFC copper
Microphone
Weight3.6g / earphone
ColorSilver
Package1x 7Hz x Crinacle ZERO:3
1x 3.5mm Jack to CIEM cable with mic
6x Pairs of ear tips
ColorSilver
Impedance (Ω)30
Efficiency / Sensitivity (dB)105.0
WirelessNo
Cable terminationJack 3.5mm
Phone call featureYes
Noise reductionNo
7HZ x CRINACLE ZERO:3 Dynamic In-Ear Monitors IEM 105dB 30 Ohm 10Hz-20kHz 3.5mm Jack Mic Silver
The 7Hz x Crinacle ZERO:3 are wired in-ear monitors with a 10 mm dynamic driver, designed around a composite diaphragm with a metal dome. Combined...
