DDHIFI MEMORY AL4.4 In-Ear Monitors IEM
The dd HiFi Memory AL4.4 are in-ear headphones featuring planar magnetic drivers, designed to reproduce sound with precision and stability. They incorporate a driver developed in collaboration with Moondrop, featuring a dual suspension system and a four-pole magnetic circuit to better control the movement of the diaphragm, thereby improving sensitivity whilst minimising distortion.
Reference : 21924
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 11-11-2026.
ddHiFi Memory AL4.4 In-Ear Monitors IEM Planar Magnetic 16 Ohm 121dB 20Hz-20kHz
dd HiFi Memory AL4.4 : Front view
The ddHiFi Memory AL4.4 are in-ear monitors featuring planar magnetic drivers, designed to reproduce sound with precision and stability. They incorporate a driver developed in collaboration with Moondrop, featuring a dual suspension system and a four-pole magnetic circuit to better control the movement of the diaphragm, thereby improving sensitivity whilst minimising distortion.
They combine an aluminium alloy housing, whose rigidity minimises unwanted resonance, with a shielded cable that protects the signal from electromagnetic interference. This design ensures consistent sound reproduction, free from any colouration caused by the chassis or the signal transmission.
ddHiFi Memory AL4.4: Planar magnetic driver
The Memory AL4.4 features a planar magnetic driver developed in collaboration with Moondrop, utilising a dual-suspension system for the diaphragm to stabilise its movement and minimise mechanical distortion under high stress. This design is complemented by a four-pole magnetic circuit, increasing the flux density applied to the diaphragm, which improves sensitivity whilst maintaining precise control over movement. The result is low non-linear distortion, preserving the clarity of subtle details at low volumes, whilst low harmonic distortion at high levels ensures stable reproduction even during prolonged listening sessions.
dd HiFi Memory AL4.4 : Driver
dd HiFi Memory AL4.4 : Earphone
dd HiFi Memory AL4.4: Aluminium housing
The system features an aluminium alloy chassis, whose structural rigidity minimises unwanted resonance, whilst the retro design forms part of an aesthetic approach that contrasts with a sound reproduction focused on contemporary precision. This consistency extends to the cabling, with a shielded cable that isolates the signal from electromagnetic interference, thereby preserving the integrity of the information transmitted to the drivers.
ddHiFi Memory AL4.4: Retro-style carry bag
To ensure you can take them with you wherever you go, the Memory AL4.4 come with a synthetic leather carrying case designed to resemble a cassette player. The case features two separate internal compartments to prevent the metal earpieces from scratching each other.
dd HiFi Memory AL4.4 : bag
Product typeIn-ear monitors (IEM)
DriverPlanar magnetic 13mm
Cable connectorJack 4.4mm
Frequency response20Hz-20kHz
Impedance16Ω
Sensitivity121dB
Total harmonic distortion (THD)≤0.1%
Body materialAluminum
Cable conductor5N OCC copper
Cable length1.2m
Weight25g
ColorSilver
Package1x ddHiFi Memory AL4.4
1x Carrying case
3x Pairs of ear tips (S / M / L)
ColorSilver
Impedance (Ω)16
Efficiency / Sensitivity (dB)121.0
WirelessNo
Cable terminationJack 4.4mm
Headphone / Earphone connectorNC
Phone call featureNo
Noise reductionNo
DDHIFI MEMORY AL4.4 In-Ear Monitors IEM Planar Magnetic 16 Ohm 121dB 20Hz-20kHz
The dd HiFi Memory AL4.4 are in-ear headphones featuring planar magnetic drivers, designed to reproduce sound with precision and stability. They...
