DUNU SA6 MK2 In-Ear Monitors
The SA6 MK2 are in-ear earphones featuring a total of six balanced armature drivers combined with a crossover system that combines physical and electronic solutions for a sound that is both smooth and detailed. Their aesthetics, a combination of wood, gold particles and resin, give each piece a unique design for a look that is both understated and distinguished.
By buying this product you get 57 loyalty points
Reference : 21043
579,00 €tax incl.
482,50 € tax excl.
Shipping date: 28-04-2026.
Dunu SA6 MK2 In-Ear Monitors IEM Balanced Armature 24 Ohm 114dB 5Hz-40kHz
Dunu SA6 MK2 : Front view
The Dunu SA6 MK2 are in-ear earphones featuring a total of six balanced armature drivers combined with a crossover system that combines physical and electronic solutions for a sound that is both smooth and detailed. Their aesthetics, a combination of wood, gold particles and resin, give each piece a unique design for a look that is both understated and distinguished.
Dunu SA6 MK2: A total of 6 drivers per side
The SA6 MK2 adopts an architecture based entirely on balanced armature drivers specially configured to ensure consistent reproduction across the entire audible spectrum. In the bass range, two custom transducers are dedicated to low frequencies. They are combined with an airflow control valve, which regulates the internal pressure of the cavity. This combination improves impact and depth while avoiding excessive compression, ensuring powerful, fast and well-defined bass.
The midrange is handled by two Knowles balanced armature drivers, optimised for mid and mid-high frequencies. Their linear response and low distortion ensure detailed and natural sound reproduction. This configuration provides a smooth transition between dynamic bass and clear treble.
Finally, two additional Knowles balanced armature drivers are dedicated to high frequencies. Designed to work in the treble range, they deliver accurate reproduction with good extension and an airy timbre.
Dunu SA6 MK2 : balanced armature drivers
Dunu SA6 MK2 : crossover view
Dunu SA6 MK2: Hybrid crossover
Equipped with a three-channel independent sound wave guidance system and an electronic frequency division controller, the SA6 MK2 features a dual-channel physical and electronic frequency division system that delivers a controlled frequency response with rare precision. This system coordinates the six balanced armature drivers to deliver smooth, natural sound with a wide soundstage and excellent clarity.
Dunu SA6 MK2: Two frequency response settings
Dunu has equipped the SA6 MK2 with a switch that offers users two different sound signatures. The standard setting (‘1’) provides a precise and balanced response, while the alternative setting (‘ON’) offers greater presence in the low frequencies for a warmer and more dynamic sound.
Dunu SA6 MK2 : Frequency response curve
Dunu SA6 MK2: A unique aesthetic
The Dunu SA6 MK2 are made with exceptional craftsmanship. Their shells are entirely handmade and feature specially selected stabilised solid wood panels. Each panel has similar colours but different textures, making each piece unique. They are coated with a resin mixed with gold powder that flows through the pattern to create a result of rare elegance.
Dunu SA6 MK2 : example of different design
Dunu SA6 MK2 : front view
Dunu SA6 MK2: Wearing comfort
The same level of attention has been paid to wearing comfort as to sound reproduction. The SA6 MK2 features an optimised and improved shape thanks to a new ear cup design. The result is a more rounded shape for optimal wearing comfort.
Dunu SA6 MK2: Detachable cable with interchangeable termination
The SA6 MK2 comes with a detachable silver-plated copper cable, ensuring optimal conductivity for lossless signal transfer. It is equipped with interchangeable terminations, allowing you to easily switch between a single-ended 3.5mm jack output and a balanced 4.4mm jack output, depending on your devices and preferences.
Dunu SA6 MK2 : earphones with their cables
Product typeIn-ear monitors
Drivers6x Balanced Armature drivers
Frequency response5Hz-40kHz
Impedance24Ω
Sensitivity114dB
Total harmonic distortion (THD)0.5% @ 1kHz
Earphone connectorsCIEM 0.78mm 2 pins
Cable terminations providedJack 3.5mm
Jack 4.4mm
Cable length1.2m
ColorWood
Package1x Dunu SA6 MK2
1x Earphone cable
1x 3.5mm jack termination
1x 4.4 mm termination
1x Carrying case
1x 3.5mm to 6.35mm jack adapter
11x Pairs of ear tips
ColorWood
Impedance (Ω)24
Efficiency / Sensitivity (dB)114.0
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
DUNU SA6 MK2 In-Ear Monitors IEM Balanced Armature 24 Ohm 114dB 5Hz-40kHz
The SA6 MK2 are in-ear earphones featuring a total of six balanced armature drivers combined with a crossover system that combines physical and...
