HIDIZS ST2 PRO NEBULA IEM In-Ear Monitors
The Hidizs ST2 Pro Nebula are 10mm dynamic driver in-ear monitors designed to cover an extended range from 20Hz to 40kHz, relying on a PU+PEEK composite diaphragm to ensure accurate and consistent reproduction across the full spectrum. They integrate a dual internal/external N52 magnet circuit, increasing flux and driver efficiency to improve transient response and bass control while limiting distortion — an approach further extended by a dual-cavity structure that reduces resonances and preserves fine detail.
Reference : 22145
29,91 €tax incl.
24,92 € tax excl.
Hidizs ST2 Pro Nebula Dynamic IEM In-Ear Monitors Jack 3.5mm 32 Ohm 108dB 20Hz-40kHz
Hidizs ST2 Pro Nebula : Front view
Hidizs ST2 Pro Nebula: 10mm Dynamic Driver
The dynamic driver of the Hidizs ST2 Pro Nebula, featuring a PU+PEEK composite diaphragm, ensures accurate and detailed sound reproduction. This driver extends high-frequency rendering, delivering the ST2 Pro Nebula's wide frequency response of 20Hz–40kHz across a broad audio spectrum.
Hidizs ST2 Pro Nebula : Dynamic driver
Hidizs ST2 Pro Nebula : N52 magnetic circuit
Hidizs ST2 Pro Nebula: N52 Magnetic Circuit
The ST2 Pro 3.5mm earphones are based on a dual internal/external magnetic architecture using N52 magnets, which increases the magnetic flux and the transducer’s efficiency to control the diaphragm’s movements more precisely. This approach improves transient response, extends the bass response whilst reducing distortion, whilst the dual-chamber structure limits unwanted resonances, contributing to a cleaner sound and better preservation of micro-details.
Hidizs ST2 Pro Nebula: An Audiophile Detachable Cable
The detachable cable of the Hidizs ST2 Pro Nebula is made from OFC (Oxygen-Free Copper) for highly reliable signal transmission. This choice of material minimises losses and interference, ensuring signal purity from source to ear.
Hidizs ST2 Pro Nebula : Detachable cable
Product typeIn-ear monitors (IEM)
DriverDynamic Ø10mm
Shell materialResin + aluminium alloy engraving
Frequency response20Hz-40kHz
Sensitivity108dB
Impedance32Ω
Microphone for phone calls
Detachable cable
IEM connectorCIEM 0.78mm
Cable termination3.5mm jack
Cable conductor materialOFC copper (4x260)
Cable length1.2m
ColorWhite
Package1x Hidizs ST2 Pro Nebula
3x Pairs of ear tips
1x Carrying pouch
ColorWhite
Impedance (Ω)32
Efficiency / Sensitivity (dB)108
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
HIDIZS ST2 PRO NEBULA Dynamic IEM In-Ear Monitors Jack 3.5mm 32 Ohm 108dB 20Hz-40kHz
The Hidizs ST2 Pro Nebula are 10mm dynamic driver in-ear monitors designed to cover an extended range from 20Hz to 40kHz, relying on a PU+PEEK...
