KZ EDZ In-Ear Monitors Dynamic IEM USB-C White
The KZ EDZ are dynamic in-ear monitors (IEMs) designed to deliver detailed and balanced sound reproduction.
Reference : 22234
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 01-12-2026.
KZ EDZ Dynamic IEM In-Ear Monitors USB-C 24 Ohm 107dB 7Hz-45kHz White
KZ EDZ
The KZ EDZ are dynamic IEM in-ear monitors designed to deliver detailed and balanced sound reproduction. They feature a dynamic driver with an ultra-wide frequency range and long excursion, developed by KZ, covering a frequency response from 7Hz to 45kHz. Thanks to their 24Ω impedance and 107dB/mW (@1kHz) sensitivity, they deliver dynamic and accurate sound across a wide range of devices. This version is equipped with a 120 ± 5cm USB-C cable featuring a dual high-definition microphone, allowing direct connection to smartphones, tablets, and USB-C compatible devices. Their ergonomic in-ear design ensures excellent wearing comfort and effective passive noise isolation, while their dual acoustic damping system provides natural sound reproduction with perfectly controlled treble.
KZ EDZ: Ultra-Wideband Dynamic Driver
The KZ EDZ feature a long-excursion dynamic driver equipped with a magnetic circuit using high-performance neodymium magnets. This design improves diaphragm control throughout its entire excursion, delivering deep, punchy bass, rich midrange, and detailed highs. With an extended frequency response from 7Hz to 45kHz, they reproduce even the finest musical nuances with excellent dynamics and transient response.
KZ EDZ: Dual Acoustic Damping System
To achieve more natural sound reproduction, the KZ EDZ employ a dual damping system combining an integrated acoustic nozzle damper with a metal sound filter. This architecture effectively reduces sibilance and harshness in the high frequencies while maintaining an excellent level of detail, resulting in a smoother and more faithful listening experience.
KZ EDZ: USB-C Connectivity and Dual HD Microphone
This version of the KZ EDZ features a USB-C cable with an integrated dual high-definition microphone. The two microphones, positioned to optimize voice pickup in various usage scenarios, ensure clear phone calls as well as excellent communication quality during gaming sessions and video conferences. The USB-C connection allows direct use with compatible devices without the need for an adapter, providing a simple and modern user experience.
Technical Specifications
Product typeIn-ear monitors (IEMs)
DriverDynamic
Impedance24 ohms
Sensitivity107dB/mW @1kHz
Frequency response7-45000Hz
Detachable cable
Connectors0.75mm
TerminationUSB-C
Cable length120±5cm
Cable conductor materialSilver-plated copper
Microphone
ColorWhite
Package contents1x KZ EDZ In-Ear Monitors
1x Detachable cable with 0.75mm connectors and USB-C termination
ColorWhite
Impedance (Ω)24
Efficiency / Sensitivity (dB)107
WirelessNo
Cable terminationUSB-C
Phone call featureYes
Noise reductionNo
KZ EDZ In-Ear Monitors Dynamic IEM USB-C Jack 24 Ohms 107dB 7Hz–45000kHz White
