HIFIMAN RE-800 "Audiophile" In-Ear Monitor 24k Gold Edition
The Hifiman RE800 are exceptional in-ear headphones that we offer in their 24k Gold Edition. They provide exceptional sound reproduction.
KEY POINTS:
  • Plating Gold 24k
  • Dynamic Drive 9.2mm
  • Silver Plated Copper Cable
Reference : 12035
699,00 €tax incl.
582,50 € tax excl.
HIFIMAN RE800
In-Ear Headphones Hifiman RE800
24k Gold Edition
If the brass used for the body of this EMI greatly improves its acoustics, it is otherwise for audio output.
Thus, the RE800 24k Gold Edition uses an electrolytic plating giving this brilliant shine.
Topological Driver
Hifiman uses advanced technology to improve the sound reproduction of the RE800. With its "Topology Driver" Hifiman greatly improves the control and precision of its headphones, resulting in great clarity, a high level of detail and sharp nuances, while maintaining a coherent sound.
Hifiman RE800
Advanced Technology
The topological driver refers to the nano-particle-based plating of the diaphragm, applied to reproduce geometric patterns. By varying this pattern the spectrum can be manipulated to provide adays better.
The idea behind this technology is inspired by the thesis of Dr. Fang Bian's Ph.D., arguing that "different nano-materials have different structures and each of these materials has its own properties." Thus, by carefully controlling the structure of the surface of the diaphragm, you obtain acoustic results that were previously unattainable. Moreover, the distortion is greatly reduced and the dynamics improved.
Hifiman RE800
Many tests to offer you the highest quality audio
After the creation of numerous prototypes and the constant realization of user tests, HifiMan has worked to offer you exceptional audio quality.
Hifiman RE800
A structure for design and comfort
With these RE800s, Hifiman redefined the structure of its IEMs, offering an industrial design combining design and comfort. Offering a size designed for comfort and optimized insulation, these headphones push the listening experience to the highest. What's more, the cable is detachable and changeable, to adapt to all your desires.
Frequency Response20Hz - 20kHz
impedance60 Ohms
<sensitivity/ Td>105dB
Type of diaphragmtopological
connector3.5mm Jack
Driver TypeDynamic 9.2mm
PlatingGold 24k
Cable materialCopper plated Silver
Weight27g
ColorGold
Impedance (Ω)60
Efficiency / Sensitivity (dB)103.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
The Hifiman RE800 are exceptional in-ear headphones that we offer in their 24k Gold Edition. They provide exceptional sound reproduction. KEY...
