IBASSO IT01S In-Ear Monitor Dynamic Driver Nanotube Diaphragm Ø10mm 16 Ohm Gray
iBasso reinvents its range of mid-range in-ear headphones with the IT01s, specially designed for audiophiles looking for exceptional playback. Using an assembly of high-end technologies, iBasso innovates and marks a turning point in their proposal for headphones with dynamic loudspeakers.
By buying this product you get 20 loyalty points
Reference : 13924
209,00 €tax incl.
174,17 € tax excl.
iBasso IT01S
iBasso IT01S Écouteurs Intra-Auriculaires Hauts-Parleurs Dynamiques Membranes Nanotubes Ø10mm 16Ω Gris
3 integrated technologies at the service of sound
The iBasso IT01S are the first IEMs to use Tesla magnetic flux, membranes with carbon nanotubes and DLC plating together. This is the latest technology for dynamic loudspeakers. This architecture, iBasso calls it DiNaTT™.
3.8µm Carbon Nanotube dome diaphragm
DLC coating on the dome diaphragm
High Tesla Magnetic Flux
Carbon Nanotube Diaphragm & DLC Coating
The DiNaTT™ technology offers the thinnest carbon nanotube dome membrane with only 3.8µm. This extreme thinness makes these membranes extremely easy to move. The membrane also uses the advances associated with the use of carbon nanotubes and DLC plating on the dome. Nanotubes provide greater membrane stiffness to extend the frequency response range and improve dynamic response. The DLC plating of the dome provides a better transient response, greater stability and more accurate highs.
Tesla Magnetic Flux
The use of Tesla magnetic flux allows the 3.8µm thick membrane to be moved with great ease. This contributes greatly to improving the definition of bass and dynamics.
Precision assembly and intelligent design
The IT01s benefit from a global design of very high quality, leaving no room for chance, in order to ensure the most transparent and rich sound reproduction possible. The shape of the IEMs has been designed to fit all ears, for optimal comfort and support.
Cable
The IT01s are delivered with a 5N single crystal copper cable with silver shielding. This is a symmetrical MMCX cable with 2.5mm connectors. A 2.5mm TRRS to 3.5mm TRS adapter is also provided.
Package
Product typeIn-Ear Monitor (IEM)
Frequency response10Hz - 43kHz
Impedance16Ω
Noise attenuation-26dB
Power10mW
Sensitivity109dB +/-2dB
THD< 1% (@ 1kHz/1mW)
Connectors dimensions2.5mm
Connectors platingGold
Cable length1.2m
Weight (without cable)8g
Package1x iBasso IT01S In-ear monitors
1x Balanced MMCX 2.5mm cable
1x Jack 2.5mm TRRS to 3.5mm TRS adapter
1x Storage box
9x Pairs of silicone tips
2x Pairs of foam tips
2x Potection screen
ColorGray
iBasso reinvents its range of mid-range in-ear headphones with the IT01s, specially designed for audiophiles looking for exceptional playback....
