KIWI EARS AIROSO In-Ear Monitors IEM
The Kiwi Ears Airoso are wired hybrid in-ear monitors (IEMs) featuring a 1 dynamic driver + 4 balanced armature driver configuration, designed to deliver a precise, detailed and immersive listening experience in a lightweight and comfortable form factor. Thanks to Precision Crossover technology, combining physical and RC networks, the frequency response is smooth and well integrated across the entire spectrum, providing a balanced sound signature with reduced distortion and excellent clarity.
Reference : 21517
135,00 €tax incl.
112,50 € tax excl.
Shipping date: 02-06-2026.
Kiwi Ears Airoso Hybrid In-Ear Monitors IEM 1DD + 4BA 18 Ohms 110dB 20Hz-20kHz
Photo of KIWI EARS AIROSO
The premium construction combines a CNC-machined aluminum alloy and titanium faceplate with a 3D-printed resin shell, ensuring durability, light weight and long-lasting comfort for extended listening sessions. The detachable cable with 0.78mm CIEM connectors and a 3.5mm jack termination offers flexibility and customization, making the Airoso compatible with a wide range of portable and desktop audio equipment.
Kiwi Ears Airoso: Hybrid 1DD + 4BA Architecture
The Kiwi Ears Airoso rely on a carefully optimized hybrid acoustic architecture combining a custom dynamic driver with four balanced armature drivers. The dynamic driver features a composite LCP + PU diaphragm, selected for its rigidity, low mass and excellent damping properties, ensuring extremely low distortion and consistent performance at any listening level. This design delivers deep, fast and well-controlled bass while maintaining excellent midrange clarity.
The four balanced armature drivers complement this foundation with dedicated roles: two drivers handle the high frequencies, while the remaining two extend the response into the ultra-high range. This configuration enhances precision, instrument separation and micro-detail reproduction, resulting in an immersive, detailed and well-balanced soundstage across the entire frequency range.
KIWI EARS AIROSO: Hybrid 1DD + 4BA Architecture
KIWI EARS AIROSO: Premium design & long-term comfort
Kiwi Ears Airoso: Premium Design & Long-Term Comfort
The Airoso’s design clearly reflects its high-end positioning. The earphones combine a CNC-machined aluminum alloy and titanium faceplate, ensuring rigidity and refined finishing, with a 3D-printed resin shell offering high dimensional accuracy. This combination of materials results in a product that is both robust, durable and lightweight, perfectly suited for everyday use.
Special attention has also been given to ergonomics: the housing naturally conforms to the shape of the ear, providing a secure and comfortable fit even during long listening sessions. This design helps reduce both auditory and physical fatigue, making the Airoso an excellent choice for audiophiles seeking a balance between sound quality, long-lasting comfort and durability.
Kiwi Ears Airoso: Detachable Cable & Versatile Use
The Kiwi Ears Airoso are equipped with a detachable cable, offering genuine flexibility and improved long-term usability. The 0.78mm 2-pin connectors ensure a reliable connection and make it easy to replace or upgrade the cable as needed, whether for switching to a balanced cable or simply replacing a worn one.
The included cable, approximately 1.2m long, provides comfortable freedom of movement for both portable and desktop use. This modular design allows the Airoso to adapt easily to a wide variety of audio setups, meeting the expectations of demanding users who value versatility, customization and product longevity.
KIWI EARS AIROSO: Detachable cable & versatile use
Technical specifications
Product typeHybrid in-ear monitors (IEM)
Driver configuration1× Dynamic driver
4× Balanced Armature drivers
Dynamic driver diaphragmLCP + PU composite
Crossover technologyPrecision Crossover (physical + RC)
Impedance≈ 18Ω
Sensitivity110dB SPL/mW
Frequency response20Hz – 20kHz
Connector3.5mm TRS (stereo jack)
CableDetachable CIEM 0.78mm (~1.2m)
Cable length1.2m
Shell materialsCNC aluminum alloy, titanium & 3D resin
Weight≈ 12 g per earphone
Package contents1x Kiwi Ears Airoso
1x Detachable 0.78 mm CIEM cable with 3.5mm jack termination
8x Pair of ear tips
1x Storage case
ColorSilver
Impedance (Ω)18
Efficiency / Sensitivity (dB)110
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
KIWI EARS AIROSO In-Ear Monitors IEM Hybrid 1DD + 4BA 18 Ohms 110dB 20Hz-20kHz
The Kiwi Ears Airoso are wired hybrid in-ear monitors (IEMs) featuring a 1 dynamic driver + 4 balanced armature driver configuration, designed to...
