KIWI EARS AETHER In-Ear Monitors IEM
The Kiwi Ears Aether are high-end universal in-ear monitors (IEMs) featuring innovative planar magnetic driver technology, built around the largest planar transducer ever developed by Kiwi Ears.
Reference : 21519
189,00 €tax incl.
157,50 € tax excl.
Kiwi Ears Aether Planar Magnetic In-Ear Monitor IEM 14 Ohm 105dB 20Hz-20kHz
Photo of KIWI EARS AETHER
The Kiwi Ears Aether are high quality in-ear monitors (IEMs) featuring innovative planar magnetic driver technology, built around the largest planar transducer ever developed by Kiwi Ears. This 15.3mm driver uses multi-layer N52 magnets to deliver an exceptional combination of power, low distortion, and dynamic performance, significantly surpassing traditional 12mm or 14mm planar drivers. This unique design allows the Aether to achieve a sound quality reminiscent of open-back headphones, with a wide soundstage, excellent spatial presentation, and remarkably precise imaging.
Thanks to their advanced acoustic architecture, the Aether reproduce a natural and well-balanced sound signature, with deep, controlled bass, accurate mids, and clear yet non-aggressive treble extension. With a low impedance of 14Ω and a sensitivity of 105dB SPL/mW, these IEMs are easy to drive from mobile sources while still capable of scaling with more powerful audio equipment. Their reliable design includes a detachable 0.78mm 2-pin CIEM cable with a 3.5mm jack termination, ensuring modularity and durability.
KIWI EARS AETHER package
Kiwi Ears Aether: Ultra-Large Planar Magnetic Driver
At the heart of the Kiwi Ears Aether lies a 15.3mm planar magnetic driver, currently one of the largest ever integrated into an IEM design. This planar transducer is powered by multi-layer N52 magnets, delivering fast transient response, low distortion, and high acoustic output. Compared to smaller drivers, it provides a more open and expansive sound reproduction, with enhanced dynamics and superior resolution across the entire frequency range.
This technology moves beyond traditional dynamic drivers and brings the listening experience closer to that of premium open-back headphones, thanks to its wide and immersive soundstage, improved instrument separation, and precise source positioning.
KIWI EARS AETHER: Ultra-Large Planar Magnetic Driver
KIWI EARS AETHER: Open Soundstage & Advanced Acoustic Design
Kiwi Ears Aether: Open Soundstage & Advanced Acoustic Design
In addition to its 15.3mm planar magnetic driver, the Aether benefits from an optimized acoustic chamber and advanced ventilation system, delivering an exceptionally open and natural presentation. This design improves airflow around the diaphragm, reduces internal resonances, and enhances stereo imaging accuracy. The result is a wide, airy, and immersive soundstage with precise instrument placement, reminiscent of open-back headphones or high-quality stereo systems, while retaining the speed and refinement characteristic of planar drivers.
Kiwi Ears Aether: Natural and Balanced Sound Signature
The Aether have been carefully tuned to deliver a balanced tonal signature aligned with Kiwi Ears’ design philosophy. The bass is deep and well-controlled, with defined impact that adds presence without overwhelming the midrange. The transition into the mid frequencies is smooth, allowing vocals and instruments to stand out clearly and naturally. The treble is finely tuned to provide rich detail without harshness, ensuring comfortable listening even during extended sessions.
This sound signature enables the Aether to perform exceptionally well across various musical genres, whether for analytical listening of acoustic recordings or immersive experiences such as gaming and cinematic soundtracks.
KIWI EARS AETHER: Natural and Balanced Sound Signature
KIWI EARS AETHER: Ergonomic Comfort & Detachable Cable
Kiwi Ears Aether: Ergonomic Comfort & Detachable Cable
The Kiwi Ears Aether feature an ergonomic medical-grade resin shell with refined finishing, designed to comfortably fit the natural contours of the ear and minimize fatigue even after several hours of listening. Their shape ensures secure positioning and effective passive isolation while remaining lightweight enough for portable use.
The detachable 0.78mm 2 pins cable system offers maximum flexibility: it allows easy replacement of the original cable if needed and enables users to upgrade to alternative cables (such as balanced versions) to tailor the listening experience according to their setup and preferences.
Technical Specifications
Product TypeIn-ear monitors (IEM)
Driver15.3mm Planar Magnetic
MagnetsMulti-layer N52 Neodymium
Impedance14Ω
Sensitivity105dB SPL/mW @ 1kHz
Frequency Response20Hz – 20kHz
Earphone Connector0.78mm CIEM (2-pin)
CableDetachable (~1.2m)
Cable Termination3.5mm Jack
Package Contents1x Kiwi Ears Aether
1x Detachable 0.78mm CIEM to 3.5mm jack cable
8x Pairs of ear tips
1x Storage case
Impedance (Ω)14
Efficiency / Sensitivity (dB)105.0
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
KIWI EARS AETHER In-Ear Monitors IEM Planar Magnetic 14 Ohm 105dB 20Hz-20KHz
The Kiwi Ears Aether are high-end universal in-ear monitors (IEMs) featuring innovative planar magnetic driver technology, built around the largest...
