MOONDROP GRAVITY POSITION In-Ear Monitors IEM
New
The Moondrop Gravity Position are wired earphones featuring a dynamic driver with an aluminum-magnesium alloy dome, designed for multimedia listening and gaming. Their USB sound card module supports audio decoding up to 24 bits and integrates a DSP allowing the sound signature to be adapted to different uses.
Reference : 22663
39,00 €tax incl.
32,50 € tax excl.
MOONDROP GRAVITY POSITION In-Ear Monitors IEM Dynamic 119dB 18 Ohm 15Hz-38kHz Black
MOONDROP GRAVITY POSITION: Front view
Intended for use with a computer, console or mobile device, they combine a USB connection with a four-pole CTIA 3.5mm jack analog link with microphone. Tuning is accessible from a Web interface or the MOONDROP app, while custom settings can be stored in the module's DSP to follow changes of equipment.
Moondrop Gravity Position: Aluminum-magnesium dome driver
The dynamic driver of the Moondrop Gravity Position uses an aluminum-magnesium alloy dome, whose rigidity and low mass promote treble extension and detail retrieval. Its suspension combines two polymer materials with different properties to control resonances and reduce non-linear distortion. Moondrop states a distortion below 0.05% across almost all frequency bands, preserving the accuracy of sounds, from explosions to footsteps.
MOONDROP GRAVITY POSITION: Driver
MOONDROP GRAVITY POSITION: In use
Moondrop Gravity Position: Tuning suited to listening and gaming
The response of the Gravity Position is tuned according to psychoacoustic principles and taking into account the frequency characteristics of the HRTF function. Combined with the aluminum-magnesium alloy diaphragm, this tuning aims for an open sound, a precise soundstage and an extended response. It allows the earphones to be used for music and films as well as for competitive gaming, where the perception of details and their positioning helps follow the action.
Moondrop Gravity Position: USB sound card and analog connection
The Gravity Position combine wired earphones with a HiFi USB sound card module, capable of decoding an audio signal up to 24 bits and running a second-generation interactive DSP function. The module can be used with different platforms or independently of the earphones, while the earphones retain a four-pole CTIA 3.5mm jack analog connection with microphone. This dual configuration allows them to be used with a computer or console via USB, or connected directly to a compatible source and audio interface.
MOONDROP GRAVITY POSITION: USB-C adapter
MOONDROP GRAVITY POSITION: NPU chip
Moondrop Gravity Position: AI voice processing
The sound card module integrates an NPU that runs an artificial intelligence voice processing algorithm. It reduces ambient noise picked up by the microphone and improves voice intelligibility during calls or gaming sessions. As the processing is handled by the hardware, it does not rely solely on the capabilities of the device to which the earphones are connected.
Moondrop Gravity Position: Graphical tuning interface
A graphical interface allows the sound signature to be adjusted according to user preferences or the game being played. It displays frequency markers associated with different games to facilitate initial settings, then allows more precise customization of gain, attenuation and frequency points. Adjusting the Q factor also makes it possible to control the width of the effect applied around each frequency, while parameter sharing and automatic calculations make it easier to compare custom profiles.
MOONDROP GRAVITY POSITION: Frequency response
Moondrop Gravity Position: Settings accessible on the Web and on mobile
The Gravity Position can be configured from a Web tuning platform or from the MOONDROP app on a mobile device. Accounts, database and app are interoperable, allowing settings to be retrieved in different usage contexts. Once applied, custom settings are saved in the DSP integrated into the sound card: they therefore remain available when changing equipment, without needing to be reset or configured again.
MOONDROP GRAVITY POSITION: EQ
Technical specifications
Product typeIn-ear monitors
Frequency response15Hz-38kHz
Impedance18Ω
Sensitivity119dB
Total harmonic distortion (THD)≤0.5%
Drivers1x Dynamic Ø10mm
Cable terminationJack 3.5mm
Earphone connectorsCIEM 0.78mm 2 pins
Package1x Moondrop Gravity Position
1x Jack 3.5mm to CIEM 0.78mm 2 pins cable
1x Jack 3.5mm to USB-C adapter
Impedance (Ω)18
Efficiency / Sensitivity (dB)119
WirelessNo
Phone call featureNo
Noise reductionNo
The Moondrop Gravity Position are wired earphones featuring a dynamic driver with an aluminum-magnesium alloy dome, designed for multimedia...
