By buying this product you get 22 loyalty points
The Noble Audio Osprey are True Wireless in-ear monitors featuring a hybrid architecture combining a 10mm dynamic driver with a custom balanced armature driver, combining impact and warmth in the bass with precision and detail. They feature Bluetooth 6.0 connectivity with support for LDAC, AAC and SBC codecs, as well as active noise cancellation ANC, a Hearing Through mode to remain aware of your surroundings and multipoint connectivity. The Osprey also feature two microphones with cVc noise reduction, TrueWireless Mirroring technology and a 500mAh aluminum charging case with USB-C charging. They offer up to 7 hours of battery life with ANC disabled or 5 hours with ANC enabled, while a 10-minute fast charge provides approximately 2 hours of listening time. They are therefore suitable for everyday music listening as well as commuting, work or travel.
The Osprey combines a 10mm dynamic driver with a custom balanced armature driver. This hybrid design allows the dynamic driver to deliver impact and warmth, while the balanced armature contributes to precision and detail reproduction. LDAC compatibility also allows high-quality Bluetooth transmission with compatible devices, while AAC and SBC codecs ensure broad compatibility with different Bluetooth sources.
Thanks to Bluetooth 6.0, multipoint connections and TrueWireless Mirroring technology, the Noble Audio Osprey are designed for versatile everyday use. The ANC system reduces external noise, while Hearing Through mode allows surrounding sounds to be heard when necessary. The two built-in microphones also benefit from cVc noise reduction to improve call management. The 500mAh aluminum charging case, equipped with a USB-C port, completes the system and allows the earbuds to be easily recharged.
Technical Specifications
| Specifications | |
| Product Type | In-ear monitors |
| Driver | Dynamic Ø10mm + Balanced Armature |
| Chipset | Airoha 1571 |
| Connectivity | Bluetooth 6.0 |
| Supported Bluetooth Codecs | LDAC / AAC / SBC |
| Active Noise Cancellation (ANC) | |
| « Hearing Through » Mode | |
| Multipoint Connectivity | |
| TrueWireless Mirroring | |
| Two Microphones with cVc Noise Reduction | |
| General | |
| Battery Life | Up to 7 hours of listening (active noise cancellation disabled) Up to 5 hours of listening (active noise cancellation enabled) |
| Charging Case Battery | 500 mAh |
| Power Supply | 5V DC via USB-C |
| Package Contents | 1x Noble Audio Osprey 1x Aluminum charging case 1x USB-C charging cable Pairs of in-ear ear tips |
| Color | Blue |
| Impedance (Ω) | NC |
| Efficiency / Sensitivity (dB) | N/A |
| Wireless | Yes |
| Cable termination | Wireless |
| Headphone / Earphone connector | Wireless (Bluetooth) |
| Phone call feature | Yes |
| Noise reduction | Yes |
