THIEAUDIO MONARCH MKIV In-Ear Monitors Stellashot
The Thieaudio Monarch MKIV are hybrid in-ear headphones with eight transducers per side, designed to articulate the entire spectrum around a coherent multi-way architecture. They combine two 8 mm dynamic drivers for bass, six balanced armature drivers for midrange and treble, and two electrostatic tweeters for ultra-high frequencies, using 4-way passive filtering to ensure precise frequency distribution and controlled transition between each register.
By buying this product you get 139 loyalty points
Reference : 21554
1 390,00 €tax incl.
1 158,33 € tax excl.
Shipping date: 13-11-2026.
Thieaudio Monarch MKIV In-Ear Monitors IEM Dynamic Balanced Armature Electrostatics 10Ω 100dB 10Hz-44kHz Stellashot
Thieaudio Monarch MKIV : Front view
The Thieaudio Monarch MKIV are hybrid in-ear monitors with ten transducers per side, designed to articulate the entire spectrum around a coherent multi-way architecture. They combine two 8mm dynamic drivers for bass, six balanced armature drivers for midrange and treble, and two electrostatic tweeters for ultra-high frequencies, using 4-way passive filtering to ensure precise frequency distribution and controlled transition between each register.
They also feature a dual-profile tuning system, selectable directly on the ear cups. This approach allows the bass and low-midrange response to be adjusted according to the desired balance, while maintaining the structure and separation offered by the hybrid architecture.
Thieaudio Monarch MKIV: Dual-profile sound signature
The Monarch MKIV introduces a new selectable tuning profile on the back of the earphones. In Standard mode, the tuning adopts a neutral base inspired by studio monitoring. The sub-bass reaches around +10dB, but a sharp cut-off at 150Hz limits its interaction with the low-mid range, maintaining firm and fast bass while preserving the clarity of vocals and instruments between 150Hz and 1kHz. This restraint in the lower spectrum allows the treble to express itself with greater clarity, emphasising vocal intelligibility and reducing excessive upper harmonics, resulting in less fatiguing listening over time.
Thieaudio Monarch MKIV : Frequency response curve
In Rumble mode, the transition to the lower midrange is smoother, enhancing the feeling of density. The sub-bass is boosted by up to +13dB, while the 200-500Hz range gains around +2dB, adding more substance to the bass lines. This setting favours a fuller, more enveloping sound, while maintaining the separation provided by the multi-way architecture.
Thieaudio Monarch MKIV: IMPACT 2 System
The Monarch MKIV features the second generation of the IMPACT 2 subwoofer system, based on two 8mm dynamic drivers with composite cones, housed in a proprietary pneumatic acoustic chamber to generate high infrabass pressure while mechanically isolating the rest of the spectrum.
Thieaudio Monarch MKIV: Hybrid architecture
In addition to the two dynamic bass drivers, the Monarch MKIV structures the rest of the spectrum around a progressive distribution of technologies to ensure seamless tonal continuity between registers.
Two balanced armature drivers handle the midrange, ensuring precise vocals and clear instrumental textures, while four other balanced armature drivers handle the high frequencies, ensuring defined attacks and clarity in the presence range. This internal separation optimises each frequency range without overloading a single transducer, resulting in more stable reproduction at sustained levels.
Beyond that, two electrostatic tweeters handle the ultra-high frequencies, extending the response up to 40 kHz and providing an additional sense of airiness. This hierarchy, with dynamic drivers for the foundation, balanced armature drivers for the tonal structure, and electrostatic drivers for the extension in the high frequencies, results in a coherent spectrum with a smooth transition between impact, definition and openness.
Thieaudio Monarch MKIV: Modular cable
The Monarch MKIV comes with a cable made of OFC copper and silver-plated OFC copper, ensuring optimal conductivity to get the most out of the earphones' performance.
The termination is interchangeable, with single-ended 3.5mm jack and balanced 4.4mm jack plugs provided. This modularity allows the earphones to be directly adapted to an audiophile portable music player or a more conventional earphones output, without the need for an external adapter.
Thieaudio Monarch MKIV : Cable
Product typeIn-ear monitors (IEM)
Drivers2x Dynamic drivers
6x Balanced armature drivers
2x Electrostatic drivers
Impedance10Ω (±1Ω)
Sensitivity100dB ±1dB @ 1kHz
Frequency response10Hz-44kHz
Cable connectorSingle-ended Jack 3.5mm
Balanced Jack 4.4mm
Earphones connectorsCIEM 0.78mm 2 Pins
ColorIridescent (Stellashot)
Package1x Thieaudio Monarch MKIV
1x Earphone cable
1x 3.5mm jack termination
1x 4.4mm jack termination
1x Storage box
9x Pairs of ear tips
ColorIridescent
Impedance (Ω)10
Efficiency / Sensitivity (dB)100.0
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
THIEAUDIO MONARCH MKIV In-Ear Monitors IEM Hybrid 10Ω 100dB 10Hz-44kHz Stellashot
The Thieaudio Monarch MKIV are hybrid in-ear headphones with eight transducers per side, designed to articulate the entire spectrum around a...
