ALLO VOLT+D Dual Mono Class D Amplifier 2x TPA3118D2 2x60W 4 Ohm
Allo proposes a new version of its amplifier Volt Amp with this Volt+D. This one takes the big concepts of its big brother but presents itself this time as a double mono amplifier, in Class D.
4.8 / 5
Reference : 12854
149,00 €tax incl.
124,17 € tax excl.
Allo Volt+D
Allo Volt+D Amplificateur Double Mono Class D 2x TPA3118D2 2x60W / 8ohm
ASR Review
The Allo Volt+ D amplifier is a delightful surprise. Careful design has elevated the performance of these switching "chip amplifiers" to that of mass market hifi/class AB designs. Yet, it runs cool and costs very little. Yes, you need an external power supply and that is the only flaw I see with going with this solution.
 test by the measurement forum Audio Science Review
Solid structure for quality sound
At the heart of this amplifier are two TI TPA3118D2 amplification chips, one chip per channel, allowing 2x60W to be developed. All capacitors in the audio stage have also been replaced by more powerful film capacitors. The power supply has also been improved as well as the inductance of the output stage.  Also note the presence of a volume attenuator with relay switching, normally not found on a device at this price.
In addition, it becomes possible to select the gain (20 or 26) via a switch at the rear of the device, but also to adjust the AM bandwidth avoidance circuit.
In the end, this Volt+D allows you to enjoy more power while having a lower THD+N than the Volt Amp. In addition, the unit now directly includes a volume attenuator, allowing quick and easy operation of the amplifier.
The power of the amplifier depends on the voltage supplied by the power supply. Generally, the rule is V² / R. So for 23V we will have about 60W per channel.
Amplifier typeDual mono Class D
Power2x60W 4Ω
Amplifier chip2x TI TPA3118D2
FeaturesMute Switch
Gain selector (20/26)
AM bandwitth parameters
OutputSpeaker terminal
Power supply
19V 3.2A via Jack 6.5/3.0mm (Not included but available as an accessory)
24V Max
Volume controlVia 24 stepped attenuator
Connectors plating (RCA and speaker terminals)Plaquage Or
Case5mm transparent acryilic
ColorOther
ChannelDual Mono
Amplifier chipTPA3118
Power (W)60.0
12 reviews
review
The sound is clear and transparent. It's very cost-effective
This review has been posted for ALLO VOLT+D Dual Mono Class D Amplifier 2x TPA3118D2 2x60W 4 Ohm
Crisp & Clear - highly recommended
I’ve had this for a few days now and hooked it up to a variety of hardware. Presently replacing my ancient EL34 valve amplifier in my main system. Quite a contrast. Everything sounds more modern.
Usual superlative service from Audiophonics. I chose the cheapest, non-tracked option for delivery to my home in Portugal. It arrived tracked within two days, the delivery slot midway between the notified one-hour time slot.
Je recommande
Petit ampli pauvre en fonctionnalités mais qui mesure vraiment très bien pour son prix.
Je n'ai pas fait de test ABX mais l'écoute est très plaisante. Mon autre ampli est un intégré bas de gamme Pioneer de même puissance de référence A209-R.
Le VOLT+D est très silencieux à faible volume (bon rapport signal/bruit, bien meilleur que le Pioneer).
Je l'utilise en écoute de proximité sur de petites biblio Monitor Audio Monitor 100, avec l'alimentation vendue séparément sur Audiophonics (19V 3.15A). Le réglage de gain de 20dB est largement suffisant dans ces conditions d'écoute (potard de volume à 8 positions du max).
Au besoin il y a 2 switches sur le dessous à changer de position pour passer à 26dB de gain, et il est possible d'utiliser des alimentations plus puissantes.
Promesses non tenues
Bonjour,
je l'ai acheté au vu des avis clients, mais les plutôt bonnes impressions des premières écoutes n'ont pas évolué après quelques dizaines d'heures. Je pense qu'il manque de médiums, qu'il est écourté dans les graves et aigus (mes CDs préférés de référence en attestent, comparés à mes 3 autres petits amplis). Les sonorités restent trop en retrait, l'épanouissement sonore auquel je m'attendais ne se produit toujours pas. J'ai des enceintes colonnes Magnat, un lecteur CD Marantz et un dac PS Audio. Et aussi, achetés sur Audiophonics, le Qinpu A6800, très musical sans être dynamique et détaillé, le FX Audio 1002A, lui très (trop?) dynamique et généreux. Donc ce Volt+D me parait bien timide en comparaison, malgré ses timbres nets et aérés et ses graves bien tenus. Enfin, pour les amateurs curieux, je recommande le petit ampli TBI Millenium G3, de l'Américain Jan Plummer. Il fonctionne sur secteur ou piles (c'est là qu'il est le plus étonnant), mais hélas trop cher je trouve (compter des frais de douane).
Excellent ampli
J'ai acheté cet ampli chez audiophonics (service client très bien avec conseils avant et après achat) il y a un an. Il fonctionne avec un raspberry pi comme source numérique, un DAC SMSL Sanskrit, et derrière des enceintes Davis Acoustis Olympia One Master. Le résultat est très bon.
J'ai comparé avec attention avec un SMSL AD18 (qui prend le signal numérique sans avoir besoin de DAC) : le AD18 est plus punchy sur les basses, très "direct" (ce qui est il faut bien dire très séduisant aussi). Mais le Volt+D est plus équilibré, avec des timbres plus riches et nuancés des basses aux aigus, et au final une scène plus réaliste, et c'est pour cela que je l'ai retenu. L e Volt+D reste étonnant sur la propreté des attaques et autres "transitoires" : les percussions sont très présentes, c'est presque troublant sur des cymbales. La fidélité et le respect de tout le spectre me paraît marquante, jusqu'aux aigus. Je n'ai pas comparé à des amplis chers et haut-de-gamme, je peux simplement dire que le son dans mon système modeste me paraît très bon et réaliste. J'entends très bien les différences entre des bons enregistrements, surtout en qualité CD, par rapport d'autres moins bons : la séparation des instruments, la présence dans la pièce des instruments, sont très agréables et réalistes, et en fermant les yeux, on y est... surtout sur des petits ensembles, jazz et vocal (mon petit système reste moins précis et réaliste sur des grands orchestres, mais je ne sais pas dire le rôle des enceintes, de la pièce, et de l'ampli).
Allo proposes a new version of its amplifier Volt Amp with this Volt+D. This one takes the big concepts of its big brother but presents itself this...
