IEAST AMP-I50B Pro Wireless Wall-Mount MultiRoom Stereo Amplifier 2X40W 8 Ohm
The iEast AMP-i50B is a small Class D amplifier with the particularity to integrate a complete network connectivity, allowing you to simply stream your music remotely from a device connected to the same network (smartphone, computer, NAS...) or from a compatible streaming service.
By buying this product you get 31 loyalty points
Reference : 11859
319,00 €tax incl.
265,83 € tax excl.
iEast AMP-i50B
iEast AMP-i50B Amplificateur Professionnel Sans-Fil Multiroom Mural 2x40W 8 Ohm
The iEast AMP-i50B is a small Class D amplifier with the particularity to integrate a complete network connectivity, allowing you to simply stream your music remotely from a device connected to the same network (smartphone, computer, NAS...) or from a compatible streaming service. The amplifier can also work in a multi-room environment, allowing you to sound several rooms in your home and control their playback via a dedicated application.
The on-board amplifier is capable of delivering a power of 2x40W at 8Ω with a high efficiency, above 90%, inherent to Class D. A digital DSP allows an efficient processing of the audio signal, ensuring a musical resititution with low distortion and high current capacity. Integrated in a metal housing, the heat of the components is efficiently dissipated thanks to adapted heat sinks. Another special feature of the AMP-i50B is that it can be mounted on a wall, which is particularly convenient for integration in a multi-room system.
Connectivity
The AMP-i50B therefore benefits from a particularly comprehensive connectivity and connectivity. WiFi and Bluetooth will allow you to broadcast your music remotely in an extremely simple way. The device also has a Micro SD slot, a USB-A port (for storage devices), an RJ45 connector and a 3.5mm jack line input. An RS232 serial port is also available in 3.5mm jack format. Finally, it is possible to remote the infrared receiver according to your installation.
iEast Play App
Control is simple and intuitive from the dedicated iEast Play application, available free of charge for Android and iOS devices.
Streaming
The AMP-I50B is compatible with many streaming services, allowing you to easily stream your music from any of them: Spotify, Qobuz, Deezer, Tidal, Tune In...
Product typeAmplifier
Amplification typeClass D
Power40W @ 24V, 6Ω, THD 0.7%
20W @ 24V, 6Ω, THD 0.06%
30W @ 24V, 8Ω, THD 0.4%
20W @ 24V, 8Ω, THD 0.12%
InputsMicro SD
USB-A
Line input Jack 3.5mm
Serial port RS232 via Jack 3.5mm
WiFi 802.11 b/g/n
Ethernet RJ45 10/100Mbit
Bluetooth 4.0
OutputSpeaker terminals
Streaming servicesSpotify, Qobuz, Deezer, Tidal, Tune In, iHeartRadio, Pandora, Napster, radios internet, QQ Music...
Wireless protocolsDLNA
UpNP
Spotify Connect
AirPlay
QPlay
WPS Compatibility
WiFi SecurityWPA
WPA2
SNR86dB
Frequency response20Hz - 20kHz (±3dB)
Supported sampling ratesUp to 24bit 192kHz
Supported file formatsMP3, AAC, AAC+, ALAC, FLAC, APE, WAV
Control appiEast Play
Firmware 4.2.7709.27Deezer support
Amazon Music support (US only)
Streaming directly from the application
Adjustment of bass and treble from application
Adding predefined profiles
Optimization of stability and reliability
Power supply24VDC 3.3A
Min/Max operating temperature-5°C / 40°C
Housing materialMetal
Dimensions146 x 134 x 31mm
Weight1.3kg
Package1x iEast AMP-i50B
1x WiFi antenna
1x Bluetooth antenna
1x IR receiver cable
1x IR remote control
1x Power supply
1x Power cable
InputMicro SD
InputWiFi
InputRJ45
DAC / ADC ChipNC
Amplifier chipN/A
The iEast AMP-i50B is a small Class D amplifier with the particularity to integrate a complete network connectivity, allowing you to simply stream...
