SMSL DA-6 Class D Amplifier Infineon 2x70W 4 Ohm Black
-10%
The SMSL DA-6 is a small, practical, high-performance and affordable Class D amplifier based on an Infineon amplifier chip offering high efficiency and capable of developing 2x70W of power under 4Ω, while offering dynamic and accurate sound reproduction. Its simple and efficient design endows it with a stereo RCA input, LED display and digital volume control, all dressed in a robust and modern CNC machined aluminum chassis.
3.5 / 5
Reduced price!
Reference : 16592
99,00 €tax incl.
-10%
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 15-09-2026.
SMSL DA-6
Class D Amplifier Infineon 2x70W 4Ω Black
SMSL DA-6 Amplificateur Class D Infineon 2x70W 4Ω
The amplifier adds to this the possibility of adjusting the bass and treble levels over a range of ±14dB (Tone mode) as well as five predefined equalizers and a mode allowing to bypass all equalizers (Direct mode). This makes it possible to adapt the sound of the DA-6 to your listening style, your favorite music genre and your audio system.
1Display
2IR Receiver
3Multifunction button
4RCA input
5Right channel speaker output
6Left channel speaker output
7Power connector
Product typeAmplifier
Amplification typeClass D
Input1x Stereo RCA
OutputSpeaker terminals
Output power2x 70W @ 4Ω
Frequency response20Hz - 40kHz
Bass/Treble adjustable gain-14dB / +14dB
THD+N0.004%
Channels separation91dB (1kHz)
Input sensitivity400mVrms
SNR103dB
Max input voltageLow gain: 2Vrms
High gain: 1.2Vrms
Supply voltage24VDC
Consumption36W
Dimensions140 x 110 x 28mm
Weight350g
SMSL DA-6 Amplificateur Class D Infineon 2x70W 4Ω SMSL DA-6 Amplificateur Class D Infineon 2x70W 4Ω
Channel2 (Stereo)
Amplifier chipN/A
Power (W)70.0
Remote ControlYes
2 reviews
Pas aimé le son
Son aseptisé. Il est peu puissant, mais il y a les réglages basses, aigus, brillance, suround...qui donne de l'intensité sonore. (branché sur des hauts parleurs de 10cm, eltax monitor I, 87db)
A part la télécommande pratique, et le petit boitier bien fait, des connecteurs correctes, l'écran numérique, il est pas très utile. Pas de bluetooth.
Il y a mieux sur ce site, pour la richesse sonore.
This review has been posted for SMSL DA-6 Class D Amplifier Infineon 2x70W 4 Ohm Black
Minimal, mais efficace
Un petit ampli sans prétention mais précis et puissant. Parfaitement à sa place dans le salon, juste une entrée (à réserver à un DAC), pas de fioritures inutiles. Excellent rapport qualité prix. Petit défaut : il manque un petit voyant pour indiquer qu'il est allumé...
The SMSL DA-6 is a small, practical, high-performance and affordable Class D amplifier based on an Infineon amplifier chip offering high efficiency...
