TOPPING PA3 TDA7498E Class D Amplifier 2x100W 4 Ohm Silver
TOPPING PA3 TDA7498E Class D Amplifier 2x80W 4 Ohm Silver
4.3 / 5
Reference : 12617
119,00 €tax incl.
99,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
This product has been replaced by the new version, the TOPPING PA3S Class D Balanced Amplifier 2x MA12070.
TOPPING PA3 class D 2x100W Silver
High Fidelity desktop amplifer
topping PA3 2x80W 4 ohm Silver
Compact and powerful
TOPPING PA3 2x100W (@ 32V / 4Ohm) is the ideal integrated amplifier for a desktop sound amplifier system. It offers great musicality and has a lot of power reserve thanks to a Texas TDA7498E chip. It is a simple and elegant solution with two stereo input and a volume knob on its front plate.
topping PA3 2x80W 4 ohms
Intelligent Control Monitoring
TDA7498E is backed by a MCU processor to avoid over / under voltage / charge to offer a real protection to the speakers connected to Topping PA3.
Audiophile grade components
The passive components of the Topping PA3 are first-class using Nichicon capacitors known for their reliability and fidelity as well as plastic film Epcos capacitors at strategic locations on the pre-amplifying part. The potentiometer is a model from ALPS Japanese brand recognized worldwide for the seriousness of its achievements.
Technical caracteristics
SPECIFICATIONS
  • SNR : 90dB
  • Gain : 29.3dB
  • Input sensitivity : 0.6Vrms (4Ohms) 0.9Vrms (8Ohms)
  • Noise level : 0.5mV ponderation A
  • Maximum power  : 2x50W 8 Ohms / 2x100W (4 Ohms 32V)
  • THD : 0.04%
  • Frequency response : 20Hz - 20kHz (-0.2dB)
Connectivity
Inputs :
  • 2x RCA
Outputs :
  • Gold plated speaker terminals
MISC
  • Weight : 515g
  • Dimensions : 168 x 120 x 37 mm
  • Package content : power chord and power supply adapter
  • Silver color
Dimensions Topping PA3
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Amplifier chipTDA7498E
Power (W)80.0
4 reviews
Great sound with no footprint
Changed from Yamaha AS500, running on Klipsch RP160M.
That little beast can drive those speakers. I'm using it as living room apm, not desktop, but still I barely turn it up to 20-30% and it is loud enough. Compared to Yamaha amp, it is cleaner, more analytical - tighter bass and wider/further sound stage (with Yamaha the singer was between speakers right before the wall, with Topping - it is between speakers, but farther behind the wall).
It is really tiny, love it.
P.s. The rated watts are still unclear, even with the manual.
This review has been posted for TOPPING PA3 TDA7498E Class D Amplifier 2x100W 4 Ohm Silver
Sans vie
Acheté pour alimenter des Q acoustics 3020. Il est bien construit et semble solide. Il est relativement puissant et dynamique. Il a surtout l'avantage de la taille, car n'importe quel intégré class AB d'entrée de gamme fait mieux. A l'image du SMSL AD18 (que j'ai également), cet ampli n'est pas très musical, c'est froid, sans vie, aucune assise dans les basses ... comme la plupart des class D et autres FDA chinois qui sont largement overbuzzés...
Petit mais costaud
J’ai acheté cet ampli pour remplacer mon vieil Esart E150 qui avait rendu l’âme. Quand je l’ai branché la première fois, je dois dire que j’étais un peu déçu, le son etait moins défini, il manquait ce grain particulier que j’aimais beaucoup. J’ai continué à l’utiliser quand même, évidemment, et j’ai constaté au fil des heures que le son était de mieux en mieux défini, que la dynamique était éxcellente, les aigües cristallins... bref je suis désormais satisfait et convaincu qu’il s’agit d’un super ampli, et je ne regrette absolument pas mon achat ! Il faut juste un peu de rôdage.
Un Lion se cache dans ce petit ampli
Tout d'abord le design de ce petit ampli et vraiment réussit : la façade est les cotés arrondis sont du plus bel effet et change de la simple boite rectangulaire . Ensuite un point très agréable il ne chauffe quasiment pas contrairement au fx1002 , et enfin le son : très dynamique descend très bas et monte très haut en fréquence , il a une bonne linéarité et il est très agréable a écouter même sur le long terme ( ne procure pas de fatigue auditive contrairement a certain autre classe D ) .
Cet ampli s'accorde bien avec le dac topping D10 mais il est parfait avec le dac M2Tech HiFace qui est d'ailleurs encore a mon gout une excellente référence .
Cet ampli a été tester avec des Elipson Prestige 4i qui ne s'accorde pas très bien ( l'ampli met en valeur le bas medium que ces enceintes on légèrement en trop )
Tester aussi avec des Monitor Audio Silver 10 , et la l'ampli s'exprime pleinement , la musique est douce et voluptueuse quand il le faut et dynamique avec une descente dans les basses a en faire trembler mon placo ainsi q'une monter dans les extrême aigu a en être cristallin quand le besoin sans fait sentir .
Pour comparaison je dispose du SMSL AD18 qui comparer au topping et moins précis et moins agréable surtout sur le long terme , même chose avec le fxaudio d802 , et surtout n'a pas cette limite du 24bits grâce a la classe D .
Pour conclure c'est mon classe D préféré qui arrive en execo avec le FX502SPRO , avec sur le topping en prime 2 entrées analogique qui vous permette de mettre un dac et une platine vinyle .
