AMP40 Class AB Integrated Amplifier 2x50W 4 Ohm Black
This AMP40 is an efficient and inexpensive solution for enjoying a good quality Class AB amplification system. Its amplification stage is based on MOSFETs and is capable of developing no less than 2x50W at 4 Ohm, allowing it to accompany many speakers without flickering.
Reference : 13421
59,90 €tax incl.
49,92 € tax excl.
AMP40 Integrated amplifier
Class AB 2x50W 4 Ohm
AMP40 Amplificateur Intégré Class AB 2x50W 4 Ohm Noir
This AMP40 is an efficient and inexpensive solution for enjoying a good quality Class AB amplification system. Its amplification stage is based on MOSFETs and is capable of developing no less than 2x50W at 4 Ohm, allowing it to accompany many speakers without flickering. Its careful design allows it to limit distortion and noise at the output for a precise and transparent reproduction, while developing a beautiful dynamic and a wide sound image.
On the connector side, the AMP40 is simple and efficient. There is a Stereo RCA input to connect your source to the amplifier and speaker terminals with gold-plated contacts at the output. The unit also has a 3.5mm jack jack for quality listening to headphones.
All components are integrated in a simple and elegant black aluminium housing. Its compactness allows it to be integrated without any problems, even in installations where the available space is limited.
1Volume button
2Right speaker output
3Left speaker output
4ON/OFF Switch
5Power supply connector 12-14V DC (power supply sold separately)
6Headphone output
7Stereo RCA Input
Product typeIntegrated amplifier
ClassAB
Output power2x50W @ 4 Ohm
Distortion0.08%
Frequency response6Hz - 80kHz (-3dB)
Input1x Stereo RCA
OutputSpeaker terminals
1x Jack 3.5mm (headphone output)
Power supply connectorJack DC 5.5/2.5mm (12-14V)
Dimensions120 x 155 x 49mm
Weight500g
MaterialAluminium
Power supply sold separately
OutputJack 3.5mm
Power (W)50.0
This AMP40 is an efficient and inexpensive solution for enjoying a good quality Class AB amplification system. Its amplification stage is based on...
