AMPAPA D1 Amplifier
The Ampapa D1 is a Class D stereo integrated amplifier designed to power passive speakers. Its PA3255 amplifier chip allows it to deliver 2x 120W into 4Ω using a PFFB (Post Filter Feedback) architecture. It also features an adjustable high-pass filter, a pre-out output, and NE5532 op-amps mounted on replaceable DIP8 sockets.
Reference : 21573
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 01-12-2026.
Ampapa D1 Amplifier Class D TPA3255 Bluetooth 5.2 with VU Meter 2x120W 4Ωr
Ampapa D1
Designed for 2.1 systems, the Ampapa D1 features a display with digital VU meters, a balanced 6.35mm TRS jack input, Bluetooth 5.2 reception, and bass/treble controls.
It is also worth noting that the D1 is compatible with the Ampapa A1 (sold separately), with which it is designed to be used in a configuration incorporating a vinyl turntable.
Ampapa D1: Connectivity and system integration
The connectivity is functional thanks to its two speaker outputs and pre-out output, allowing for easy integration into a 2.1 system. In addition, its single-ended RCA input, balanced Jack 6.35mm TRS input, and Bluetooth 5.2 reception allow for the simultaneous connection of multiple sources. The 12V trigger input allows for synchronized power-up with other elements of the system. The high-pass filter allows control over low frequencies ranging from 30 to 200Hz.
Ampapa D1 Connectivity and system integration
Ampapa D1: Amplification and preamplification stage
The amplification stage is based on a combination of the TPA3255 chip for power conversion and a NE5532 operational amplifier. This architecture allows for a maximum output power of 2x120W into 4Ω and 2x 102W into 8Ω. In addition, via its removable glass panel, the D1 allow for replacement of the two NE5532 op-amps mounted on DIP8 with any other compatible op-amp such as the 2604 / 2134 or MUSES02.
Ampapa D1 Amplification and preamplification stage
Ampapa D1 a retro design
Ampapa D1: A retro design
The D1's OLED screen offers both a classic and practical design, with eight different styles (blue, yellow, black), allowing you to see all operations and playback information in real time. Each mode can be accessed via the remote control. In addition, the Ampapa D1 has a removable glass window on the top through which a customizable RGB light shines.
Ampapa D1: Internal diagram
Ampapa D1 Internal diagram
1Gold-plated terminals
2WIMA capacitors
3Japanese SAGAMI inductors
4Rubycon capacitors
5QCC304X Chip
62oz Copper ENIG PCB
7NE5532 op amps
8NJW1194 Chip
9Gold-plated PCB
Ampapa D1 review by Audio Science Review
" The D1 nails the functionality doesn't frequently exist in amps at multiples of its price points. Compact, is quite attractive with that nice OLED display. The packaging is of very good quality and shows no signs of cost-cutting. I am happy to highly recommend the Ampapa D1 amplifier. "
Technical specifications
Product typeIntegrated amplifier
Inputs1x Single-ended stereo RCA
1x Balanced Jack 6.35mm TRS
Bluetooth 5.2
OutputsSpeaker terminals
1x Pre-out / Subwoofer output
Type of amplificationClass D
Amplification chipTPA3255
RMS output power2x120W @ 4Ω
2x110W @ 6Ω
2x102W @ 8Ω
Maximum output power2x300W @ 4Ω
Accepted impedances4-8Ω
Frequency response20Hz-20kHz (±0.4dB)
High-pass filter frequency range20Hz-200Hz
Total harmonic distortion (THD+N)≤ 0,002%
Signal-to-noise ratio (SNR)≥ 114dB
Bluetooth chipQCC304X
Supported codecsSBC, AAC, aptX, aptX HD
Power supply voltage24-48V / ≥4A
Dimensions155 x 124 x 42mm
WeightNet: 742g
Package: 1.73kg
Package1x Ampapa D1
1x 48V 5A power supply
1x Remote control
1x Bluetooth antenna
InputJack 6.35mm
OutputSpeaker terminal
OutputSubwoofer
OutputJack 3.5mm
Channel2 (Stereo)
Channel2.1
Amplifier chipTPA3255
Power (W)120.0
Remote ControlYes
AMPAPA D1 Amplifier Class D TPA3255 Bluetooth 5.2 with VU Meter 2x120W 4Ω
The Ampapa D1 is a Class D stereo integrated amplifier designed to power passive speakers. Its PA3255 amplifier chip allows it to deliver 2x 120W...
