AUDIO-GD MASTER-10 MK3 Amplifier
The Audio-GD Master-10 MK3 sets the standard in the world of high-end integrated amplifiers, combining impressive power with rare sound reproduction finesse. Designed for the most demanding audiophiles, this amplifier stands out for its balanced Class A architecture, proprietary ACSS (Audio-GD Current Signal System), and robust construction designed to minimize vibration and preserve audio signal integrity.
By buying this product you get 344 loyalty points
Reference : 21446
3 449,00 €tax incl.
2 874,17 € tax excl.
Audio-GD Master-10 MK3 Amplifier Class A Dual Mono Balanced ACSS 2x500W 4 Ohm
The Audio-GD Master-10 MK3 sets the standard in the world of high-end integrated amplifiers, combining impressive power with rare sound reproduction finesse. Designed for the most demanding audiophiles, this amplifier stands out for its balanced Class A architecture, proprietary ACSS (Audio-GD Current Signal System), and robust construction designed to minimize vibration and preserve audio signal integrity. With 2x250W power output into 8Ω and a headphone output capable of delivering up to 50W into 40Ω, the Master-10 MK3 is equally suited to the most demanding speakers and headphone listening, offering remarkable sound dynamics and neutrality.
Audio-GD Master-10 MK3: Engineering without compromise
The Master-10 MK3 is based on a massive, ultra-clean power supply combined with a rigid aluminum chassis. These technical choices reduce distortion and improve clarity of detail, even in the most complex passages. The volume control, based on precision relays, ensures smooth and accurate progression, while the balanced ACSS Class A amplification, based solely on discrete components, ensures faithful and natural reproduction, from the most subtle silence to the most explosive crescendos. In addition, the Master-10 MK3's output stage benefits from “Linear Fidelity” technology, which maintains low distortion and excellent linearity.
Audio-GD Master-10 MK3: Design and build
Audio-GD has focused on component quality and craftsmanship, paying particular attention to every detail. The heavy, sturdy chassis reflects this pursuit of excellence, while offering optimal mechanical stability. The amplifier also features a dual-mono design, which perfectly isolates the left and right channels for optimal stereo separation.
Audio-GD Master-10 MK3: Versatility and Connectivity
The Master-10 MK3 stands out for its versatility: it can be used as both a power amplifier and a headphone amplifier, with two gain modes to suit all types of headphones. Its balanced (XLR) and unbalanced (RCA) inputs allow for easy integration into any HiFi system, while its negative feedback-free design preserves the purity of the audio signal.
Audio-GD Master-10 MK3: An immersive sound experience
The Audio-GD Master-10 MK3 is capable of reproducing a wide, detailed, and natural soundstage. Whether listening to symphony orchestras, intimate jazz, or electronic music, this amplifier offers neutrality and transparency that highlight every nuance of the recording.
Product typeAmplifier
Inputs2x Balanced XLR
1x ACSS
1x Single-ended RCA
OutputsSpeaker terminals
1x Balanced stereo XLR headphone output
Output power2x 250W @ 8Ω
2x 500W @ 4Ω
2x 1000W @ 2Ω
Headphone output power (high gain mode)2x 80W @ 25Ω
2x 50W @ 40Ω
2x 10W @ 100Ω
2x 3500mW @ 300Ω
Headphone output power (low gain mode)2x 8W @ 25Ω
2x 5W @ 40Ω
2x 1W @ 100Ω
2x 350mW @ 300Ω
SNR> 115dB
Input sensitivityXLR: 1.2V RMS
ACSS: 2mA RMS
Input impedanceXLR: 94kΩ
ACSS: < 10Ω
THD< 0.007% (2.83V RMS)
Frequency band< 0.1dB (20Hz - 20kHz)
Crosstalk> -120dB
Channels imbalance< 0.05dB
Volume control steps99
Supply voltage220-240V AC 50/60Hz
Consumption150W
Transformers power1600W (4 transformers)
Brut weight~ 37kg
Dimensions430 x 400 x 172mm
Package1x Audio-GD Master-10 MK3
1x Power cable
1x Remote control (AAA batteries not included)
Audio-GD Master-10 MK3 Courbe THD
Audio-GD Master-10 MK3 Bande de fréquence
InputACSS
InputXLR
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)500.0
Remote ControlYes
AUDIO-GD MASTER-10 MK3 Amplifier Class A Dual Mono Balanced ACSS 2x500W 4 Ohm
The Audio-GD Master-10 MK3 sets the standard in the world of high-end integrated amplifiers, combining impressive power with rare sound...
