AUDIOPHONICS DA-S250NC Class D Integrated Amplifier NCore NC252MP DAC ES9038Q2M Bluetooth 2x250W 4 Ohm 32bit 768kHz DSD256
Versatile and powerful, we offer you with DA-S250NC an integrated amplifier with digital inputs to which you can add speakers to enjoy your music in the best possible way. Combining a comfortable power amplification, a powerful DAC, a complete connectic and a precise volume control, this amplifier is a must have for those who wish to equip themselves with a qualitative sound system without having to add a multitude of devices dedicated to specific functions.
4.4 / 5
By buying this product you get 64 loyalty points
Reference : 16952
649,00 €tax incl.
540,83 € tax excl.
Shipping date: 16-12-2025.
Audiophonics Workshop amplifiers range
Audiophonics DA-S250NC
Class D Integrated Amplifier NCore NC252MP DAC ES9038Q2M Bluetooth 5.0 2x250W 4 Ohm 32bit 768kHz DSD256
Audiophonics DA-S250NC Amplificateur Intégré Class D NCore DAC ES9038Q2M Bluetooth 5.0 2x250W 4 Ohm 32bit 768kHz DSD512
Incredibly effective amplification
The real engine of this DA-S250NC, the Hypex NCore NC252MP Class D amplifier module delivers considerable power, up to 2x250W under 4Ω, with great efficiency and ease, while maintaining a compact size. Its main characteristic reveals itself in its great linearity and its ability to ensure a very low level of distortion. The DA-S250NC reveals a sound reproduction as transparent as detailed to present you your music as close as possible to its recording in studio.
The NCore NC252MP also features its own SMPS power supply, consisting of a regulated half-bridge converter with synchronous rectification on the main output rails. This design is ideally suited for integration with a Class D amplifier, providing the amplifier with a stable, clean electrical signal and capable of responding quickly to more sudden power requirements.
Enjoy your music in every detail
The DA-S250NC's digital-to-analog conversion is handled by a widely proven and audiophile-approved DAC, the ES9038Q2M from ESS Technology. This chip uses the patented HyperStream® II 32bit architecture and Time Domain Jitter Eliminator technology to deliver excellent performance. The result is incredibly accurate sound reproduction that captures every detail of your music.
This DAC also opens the door to very high resolution, supporting PCM audio streams up to 32bit 768kHz and DSD up to DSD256.
A complete connectivity to adapt to all your needs
The DA-S250NC offers a complete range of connections to easily integrate into your audio system and adapt to your use. Its rear panel features digital inputs, coaxial, optical Toslink and USB-B (XMOS). For the outputs, you can of course count on high quality speaker terminals, but also on a Pre-Out output via RCA.
This RCA output offers you several possibilities:
- connect an active subwoofer
- connect another integrated amplifier
Broadcast from your sofa
In addition to its physical connectivity, the DA-S250NC provides high quality Bluetooth 5.0 reception capability, which is extremely convenient and will allow you to stream and control your music wirelessly quickly and easily, directly from your smartphone or tablet for example.
A sober and modern design
The components are perfectly protected by a robust aluminum case. Optimal heat dissipation is provided by a series of openings on the cover and rear panel, allowing for good airflow. The front panel of the DA-S250NC features a beautiful black acrylic front panel, a modern and elegant aesthetic touch. Behind this panel is a beautiful OLED screen, which displays the volume level, the active input or the type of signal received by the device. It will also allow you to navigate through the menus and access all the options of the DA-250NC.
Audiophonics DA-S250NC review by Audio Science Review (Amir)
Test du EverSolo DMP-A6 par Audio Science Review (Amir)
Product typeIntegrated amplifier
InputsBluetooth 5.0
1x USB-B
1x Coaxial
1x Optical Toslink
OutputsSpeaker terminals
1x Stereo RCA Pre-Out
AmplifierHypex NCore NC252MP
DACESS ES9038Q2M
USB InterfaceXMOS XU208
Output power2x 250W @ 4Ω
2x 150W @ 8Ω
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD DoP up to DSD256
Coaxial / Optical : PCM up to 24bit 192kHz, DSD DoP up to DSD64
THD+N0.0015%
SNR121dB
OLED ScreenBrightness not adjustable, but switches off after 40 seconds
Power supply110-230V AC
ColorGray
Total dimensions (WxDxH)300*291*60mm
Weight2.4kg
CaseAll brushed aluminium / Black acrylic front
Package1x Audiophonics DA-S250NC
1x Remote control (batteries included)
1x Power cable
1x Bluetooth antenna
FFT measure - 5W - 4 Ohm
FFT DA-S250NC - 5W - 4 Ohm
FFT measure - 4.4V Rms No load
FFT DA-S250NC - 5W - No load
OutputSpeaker terminal
ColorGray
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)250.0
Remote ControlYes
7 reviews
Excellent
Que dire de plus, ce produit est excellent et de très haute qualité. Installation facile et utilisation ultra simple. Bravo !
This review has been posted for AUDIOPHONICS DA-S250NC Class D Integrated Amplifier NCore NC252MP DAC ES9038Q2M Bluetooth 2x250W 4 Ohm 32bit 768kHz DSD256
Excellent !
J'ai été agréablement surpris par le look et les finitions de l'appareil. Il présente très bien !
J'utilisais avant un SMSL Q5 Pro branché sur des enceintes Dali Zensor 5. Eh bien, quelle différence !
L'Audiophonics est bien moins fatigant lors d'écoutes prolongées. Les basses sont bien plus présentes... Je vais devoir revoir les réglages de mon sub.
Par contre, j'ai l'impression que la scène sonore est un tout petit peu moins large.
Globalement, je suis très content de mon achat.
Very unsatisfied
The unit I received makes a high-pitched noise whenever the screen is on (40 seconds each time a button is pressed). Feedback from Audiophonics is that this is normal and they are unable to offer any sort of remedy. So overall, I cannot recommend such a low quality product.
Well-designed, easy-to-use + powerful
I purchased one of these to drive a pair of Elac DBR62s fed by a Wiim Pro source connected to the amp via optical cable. The amp is minimalist; produces a clean, transparent sound; and is powerful enough to drive a pair of DBR62s very loud in a small- or medium-sized room without issues and with power to spare. It is well-designed; easy-to-use; rugged; doesn't take up a lot of space; and integrates neatly into my application. This is a high-quality piece of equipment made available at a fair price. It is solid enough that I didn't think twice about purchasing a 2nd unit for use with another application. Recommended.
Recommended
It works like a charm with plenty of power to drive a pair of 86 db 4 ohm tower speakers. The bluetooth connectivity was surprisingly good with fast reliable connection without drop-outs. Overall well built with satisfying knobs and buttons.
Only a few negatives comes to mind. One binding post was a little loose upon arrival, the volume was initially low but i have not had problems since the first day. Is it dependent on signal strength?
And a couple of extra inputs would be appreciated in an upcoming model.
In short, if you are in the market for a clean simple powerful integrated unit this is the one.
Versatile and powerful, we offer you with DA-S250NC an integrated amplifier with digital inputs to which you can add speakers to enjoy...
