BERRY BAK BLV-D3 2.1 Class D Bluetooth Amplifier
The Berry Bak BLV-D3 is a 2.1 Class D Bluetooth amplifier designed to drive a stereo system with a dedicated subwoofer. It delivers 2x50W alongside 100W for the subwoofer channel, relying on a TPA3116-based architecture to ensure structured spectrum reproduction while maintaining high efficiency and controlled thermal dissipation.
Reference : 22036
59,91 €tax incl.
49,92 € tax excl.
Shipping date: 17-11-2026.
BerryBak BLV-D3 2.1 Class D Bluetooth Amplifier TPA3116 2x50W+100W 4 Ohm
BERRY BAK BLV-D3: Front view
The BerryBak BLV-D3 is a 2.1 Class D Bluetooth amplifier designed to drive a stereo system with a dedicated subwoofer. It delivers 2x50W alongside 100W for the subwoofer channel, relying on a TPA3116-based architecture to ensure structured spectrum reproduction while maintaining high efficiency and controlled thermal dissipation.
Intended for compact setups requiring both integration flexibility and adaptation to listening conditions, it combines DSP-based signal processing, Bluetooth 5.0 wireless connectivity, and direct access to essential controls, allowing precise adjustment of tonal balance without the need for an external interface. This approach enables it to operate as the central element of a versatile 2.1 system.
Berry Bak BLV-D3: Dual TPA3116 chips
The Berry Bak BLV-D3 adopts a 2.1 architecture based on two TPA3116 modules, enabling it to deliver 2x50W for the stereo channels while allocating 100W to the dedicated subwoofer output. This distribution relies on Class D amplification, ensuring high efficiency while limiting thermal losses, which supports compact integration without heavy cooling constraints.
BERRY BAK BLV-D3: TPA3116 chip
BERRY BAK BLV-D3: DSD ADAU1701
Berry Bak BLV-D3: ADAU1701 DSP
The integration of an ADAU1701 DSP introduces active signal management, allowing the amplifier’s behavior to be adapted to installation constraints or listening preferences. This approach results in direct control of key parameters: channel balance, bass level, subwoofer crossover frequency, and overall volume. All controls are accessible via front-panel potentiometers, ensuring immediate adjustment without an external interface.
Berry Bak BLV-D3: Bluetooth 5.0
The BLV-D3 integrates Bluetooth 5.0 connectivity, enabling stable wireless transmission while maintaining low latency, which facilitates everyday use with mobile sources. This approach is complemented by a 3.5 mm jack line input, allowing direct wired connection when required, while a headphone output in the same format extends listening options without engaging the speakers.
BERRY BAK BLV-D3: Wireless use
Product typeIntegrated amplifier
Headphone amplifier
Inputs1x 3.5mm jack
Bluetooth
Outputs1x Headphone output jack 3.5mm
Speaker terminals
Amplification chip2x TPA3116
Output power2x50W + 1x100W @ 4Ω
Bluetooth version5.0
GainStereo: 29.62dB
Mono: 29.41dB
Signal-to-noise ratio (SNR)Stereo: 101.71dB
Mono: 100.46dB
Total harmonic distortion + noise (THD+N)Stereo: 0.028% @1kHz
Mono: 0.009%
Noise levelStereo: 138.72µV
Mono: 144.81µV
Input impedance10kΩ
Power supply voltage12-24V DC
Dimensions151 x 90.8 x 27.3mm
Weight433g
Package contents1x BerryBak BLV-D3
6x 20AWG cables 10cm
3x Wago-type connectors
1x Bluetooth antenna
InputJack 3.5mm
OutputSpeaker terminal
OutputJack 3.5mm
Channel2.1
Amplifier chipTPA3116
Power (W)100.0
Power (W)50.0
BERRYBAK BLV-D3 2.1 Amplifier Class D Bluetooth TPA3116 2x50W+100W 4 Ohm
The Berry Bak BLV-D3 is a 2.1 Class D Bluetooth amplifier designed to drive a stereo system with a dedicated subwoofer. It delivers 2x50W alongside...
