DAYTON AUDIO A400 Class AB amplifier 2x300W 4 Ohm / 1x500W 8 Ohm
Dayton Audio's A400 amplifier offers class AB symmetrical amplification with a power of 300W per channel or 500W in mono if bridged. All of this is housed in a sober chassis with exemplary cooling, and is accompanied by a host of features enabling this amplifier to find its place in a wide range of configurations.
By buying this product you get 99 loyalty points
Reference : 19258
990,00 €tax incl.
825,00 € tax excl.
Shipping date: 29-05-2026.
Grantie 5 ans
DAYTON AUDIO A400 : Front view
Dayton Audio A400 : Efficient fanless cooling
Built with a well-ventilated chassis, the A400 amplifier stays cool even during extended listening sessions. The unique symmetrical circuit design and transformer location allow for highly efficient heat dissipation cooling, so there's no need for noisy fans.
DAYTON AUDIO A400 : Interior view
Dayton Audio A400 : Powerful, distortion-free amplification
Dayton Audio's A400 benefits from a class AB symmetrical structure offering a signal-to-noise ratio of 103dB and a total harmonic distortion rate of just 0.05%, while delivering 300W output power per channel into 4 Ω. Furthermore, for more power-hungry applications, the A400 can be bridged to deliver 500W output power at 8 Ω in mono.
DAYTON AUDIO A400 : Switch view
Dayton Audio A400 : Flawless adaptability
The A400 amplifier allows you to switch seamlessly between balanced and unbalanced inputs at the flick of a switch. So whether you prefer the conveniency of RCA cables or the balanced signal quality of XLR, the A400 can meet your needs. The 12V trigger input and output mean that this amplifier can be easily integrated into a home cinema system. Moreover, in configurations of this type, the LED light on the front panel can be a nuisance, which is why it can be turned off via a switch on the back of the unit.
Product typeAmplifier
Inputs1x Stereo RCA
1x Stereo XLR
1x Trigger 12V
Outputs1x Speaker terminals
1x Trigger 12V
Amplification classClass AB
Output levelStereo : 2x300W
Mono : 500W
Total harmonic distortion (THD)≤0.05%
Signal-to-noise ratio (SNR)103dB
Frequency response15Hz-20,000Hz
Input sensitivity0.43V
Load impedance
Power supply110V - 240V
Dimensions411 x 433 x 152 mm
Net weight18.8kg
Package1x Dayton Audio A400
1x Rack mounting kit
1x Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipN/A
Power (W)500.0
Power (W)300.0
Dayton Audio's A400 amplifier offers class AB symmetrical amplification with a power of 300W per channel or 500W in mono if bridged. All of...
