DOUK AUDIO A5 PRO Integrated Amplifier
The Douk Audio A5 Pro integrated amplifier, big brother of the A5, is a small amplifier based on audiophile components with a singular aesthetic. It's based on a TPA3255 amplifier chip and OPA NE5532, enabling it to deliver output power levels of up to 2x 120W under 4 ohm with the supplied power supply. Its PFFB circuit reduces distortion and greatly improves frequency response for accurate, authentic sound reproduction.
Reference : 20712
144,00 €tax incl.
120,00 € tax excl.
Shipping date: 12-05-2026.
Douk Audio A5 ProIntegrated Amplifier PFFB TPA3255 NE5532 Bluetooth 5.1 2x120W 4 ohm
Douk Audio A5 PRO picture
Compared with the A5, it offers a number of additional features, such as bass and treble tone control, and Bluetooth 5.1 reception for reliable, stable wireless transmission. The OPAs are DIP 8 mounted for quick and easy replacement. In terms of design, there's an attractive transparent glass that allows the operation to be carried out without dismantling the unit. This glass also allows use of the RGB LED display, which sublimates the amplifier circuit and can be adjusted via DIP switch.
On the rear panel, you'll find the essentials in terms of connectors, with an RCA input, a speaker terminal output and a 3.5mm AUX jack output, enabling you to set up a 2.1-channel system with an active subwoofer, for example. The front panel also features a 3.5mm headphone output, making the A5 Pro a perfect desktop amplifier.
Douk Audio A5 PRO in action
Douk Audio A5 Pro: a powerful amplifier with PFFB circuitry
The Douk Audio A5 Pro features a TPA3255 chip coupled with NE5532 OPAs. A PFFB (Post-Filter Feedback) circuit greatly enhances the amplifier's performance. With the 48V 5A power supply supplied, the A5 Pro is able to deliver up to 2x120W of power under a 4 ohm load. This power reserve makes it possible to provide sound for a relatively large space.
The power of the Douk Audio A5 PRO amplifier
DOUK A5 Pro power table
Power supplyImpedanceOutput power
32V 5A
78W+78W
71W+71W
65W+65W
36V/6A
107W+107W
100W+100W
94W+94W
48V/5A
120W+120W
110W+110W
102W+102W
48V/10A
250W+250W
210W+210W
185W+185W
Douk Audio A5 Pro: high-performance headphones amplifier
The front panel features a 3.5mm jack headphones output capable of delivering up to 500mW under 32 ohm. The Douk Audio A5 Pro can drive headphones and IEMs with impedances from 16 to 600 Ohm.
Douk Audio A5 Pro headphones output
Douk Audio A5 Pro Bluetooth reception
Douk Audio A5 Pro: Bluetooth function
The Douk Audio A5 Pro's Bluetooth 5.1 function offers reliable, stable wireless transmission from a device such as your smartphone, for example. A practical feature for enjoying streaming applications quickly and easily.
Douk Audio A5 Pro: Tone control
The Douk Audio A5 Pro features 3 potentiometers on the front panel. One potentiometer adjusts the overall volume, and two potentiometers adjust the bass and treble tones, for a personalized sound according to the user's tastes and the file being played.
Douk Audio A5 PRO tone control
OPA NE5532 DIP8 mounted
Douk Audio A5 Pro: interchangeable DIP8 OPAs
The NE5532 OPAs are DIP8-mounted, making them easy to replace. This is made even easier by the tempered glass window on the top of the amplifier. Here's a non-exhaustive list of OPAs that can replace NE5532s: 2134/2604/5532/2068/muse02 etc.
Douk Audio A5 Pro: RGB LED system
In terms of aesthetics, the A5 Pro boasts a tempered glass window on the top and LEDs that can be easily adjusted via DIP switch.
Douk Audio A5 PRO RGB LED system
DOUK AUDIO A5 Pro overview
Douk Audio A5 PRO overview
1Power ON-OFF / Source selector
23.5mm jack headphones output
3Bass control
4Treble adjustment
5Volume control
6Bluetooth antenna
7RCA input
8AUX output 3.5mm jack
9Speaker terminal output
1024V-48V power supply via DC jack
Product typeIntegrated amplifier
Headphone amplifier
Amplification chipTPA3255
OPAOPA5532
Input1x Stereo RCA
Bluetooth
OutputsSpeaker terminals
1x AUX jack 3.5mm output
1x 3.5mm jack headphones output
Output power2x 120W @ 4 ohm (48V 5A)
Recommended speaker impedance4-8 ohm
THD+N0.003%
SNR≥ 113dB
Frequency response20Hz-20kHz (±0.7dB)
Tone control±6dB
RCA input sensitivity2V
AUX 3.5mm jack output level3.7V
Headphones output power500mW @ 32 ohm
Recommended headphones impedance16-600 ohm
Bluetooth versionBluetooth 5.1
Power supplyDC 24-48V (48V 5A power supply included)
Dimensions130 x 112 x 33mm
Weight525g
Package1x Douk Audio A5 Pro
1x 48V 5A mains adapter
OutputSpeaker terminal
OutputJack 3.5mm
Channel2 (Stereo)
Channel2.1
Amplifier chipTPA3255
Power (W)120.0
Etonnant!
Je possede 3 amplis dont un thdg...ce douk, acheté pour offrir à mon fils m'a franchement étonné surtout à son prix..c est bien timbré, dynamique, belle construction, ne chauffe pas tant qu'annoncé...a mon avis concurrence facilement des amplis jusqu'à 800-1000e...les reproches: 1 seule entrée et pas de telco..mais bon vu le prix
Habitué à du relativement hdg , je reste surpris
This review has been posted for DOUK AUDIO A5 PRO Integrated Amplifier PFFB TPA3255 NE5532 Bluetooth 5.1 2x120W 4 ohm
The Douk Audio A5 Pro integrated amplifier, big brother of the A5, is a small amplifier based on audiophile components with a singular aesthetic....
