DOUK AUDIO X1 Tube Amplifier
The Douk Audio X1 is a versatile amplifier based on the use of two JAN 5725W tubes and a TDA 7498E chip. It is therefore capable of delivering up to 2x160W into 4 ohms via its speaker terminals. In addition, it features a phono preamplifier stage with MM phono input and an output for active subwoofers, allowing you to easily enjoy a 2.1-channel audio system. You can also enjoy reliable and stable Bluetooth reception thanks to a Qualcomm QCC3034 supporting SBC, AAC, aptX, and aptX HD codecs.
Reference : 21108
154,00 €tax incl.
128,33 € tax excl.
Shipping date: 17-11-2026.
Douk Audio X1 Tube Amplifier  JAN 5725W Phono MM Bluetooth 5.0 2x160W 4 ohms
DOUK AUDIO X1 picture
The Douk Audio X1 is a versatile amplifier based on the use of two JAN 5725W tubes and a TDA 7498E chip. It is therefore capable of delivering up to 2x160W into 4 ohms via its speaker terminals. In addition, it features a phono preamplifier stage with MM phono input and an output for active subwoofers, allowing you to easily enjoy a 2.1-channel audio system. You can also enjoy reliable and stable Bluetooth reception thanks to a Qualcomm QCC3034 supporting SBC, AAC, aptX, and aptX HD codecs. Other features complete this small amplifier, such as volume and tone control for adjusting the sound output and the ability to change the tube lighting for the most aesthetic effect. Powerful and versatile, this small amplifier with a variety of features is ideal for sound systems in small to medium-sized spaces.
DOUK Audio X1: high-quality components
JAN 5654W tubes
JAN 5654W tubes
These tubes add roundness and warmth to the sound, which is appreciated by many music lovers.
7498E TDA chip
7498E TDA Chip
This amplifier chip delivers up to 2x 160W into 4 ohms for powerful amplification.
Qualcomm QCC3034 Bluetooth chip
In addition to phono and RCA inputs, Bluetooth offers a reliable and stable alternative thanks to aptX and aptX-HD codecs.
Overview of the DOUK X1
DOUK X1 overview
1Bass adjustment
2Volume control
3Treble adjustment
4Power button
5Bluetooth LED indicator
6Input selector
7Bass boost
8Tone adjustment
9Tube LED control switch
10MM phono input
11RCA input
12Bluetooth antenna
13Subwoofer output
14Speaker terminals
1519V-35V DC power supply via DC jack
Product typeTube amplifier
TubesJAN 5725W
Amplification typeTDA 7498E
OPANE5532
Bluetooth chipQCC3034
Inputs1x RCA stereo
1x MM phono input
Bluetooth
Outputs1x Speaker terminals
1x Output for active subwoofer
Output power2x 160W @ 4 ohm
THD0.5% (1kHz, 1W)
SNR≥ 90dB
Sensitivity0.775V
Frequency response20Hz-20kHz (±6dB)
Bass/treble adjustment±6dB
Supported bluetooth codecsSBC, AAC, aptX, aptX-HD
Compatible replacement tubes6K4 / 6J1 / 6J4 / 6AK5
Power supply19V-35V DC
Dimensions270 x 300 x 75mm
Weight1.66kg
Package1x Douk Audio X1 amplifier
2x JAN 5725W tubes
1x Bluetooth antenna
1x 32V 5A power adapter
InputPhono
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Channel2.1
ClassTube amp
Amplifier chipTDA7498E
Amplifier chipTube
Power (W)160.0
DOUK AUDIO X1 Tube Amplifier JAN 5725W Phono MM Bluetooth 5.0 2x160W 4 ohms
The Douk Audio X1 is a versatile amplifier based on the use of two JAN 5725W tubes and a TDA 7498E chip. It is therefore capable of delivering up...
