FIIO LEVEL 1 Itegrated Amplifier
The FiiO LEVEL 1 is a Class D power amplifier designed to drive passive speakers within a compact stereo system. It delivers up to 2x 120W into 4Ω, relying on an architecture based on the TPA3255 chip combined with a PFFB circuit in order to stabilize the frequency response and maintain consistent behavior regardless of the load, all integrated into a compact chassis combining a metal structure with wood paneling.
Reference : 22065
139,00 €tax incl.
115,83 € tax excl.
FiiO Level 1 Integrated Amplifier Class D TPA3255 Bluetooth 6.0 LDAC 2x225W 4 Ohm Black
Thumbnail of the FiiO Level 1
The FiiO LEVEL 1 is a Class D integrated amplifier designed to drive passive speakers within a compact stereo system. It delivers up to 2x120W into 4Ω, relying on an architecture based on the TPA3255 chip combined with a PFFB circuit in order to stabilize the frequency response and maintain consistent behavior regardless of the load, all integrated into a compact chassis combining a metal structure with wood paneling.
Designed for versatile integration, it combines digital, analog and wireless connectivity, including USB-C, coaxial, RCA and Bluetooth LDAC, allowing multiple sources to be centralized within a single system. This approach enables it to handle both amplification and signal management while maintaining a clean and usable signal up to 24bit 192kHz in desktop or home configurations.
FiiO LEVEL 1: Amplification architecture and reproduction
The LEVEL 1 relies on a Class D amplification stage based on a TPA3255 chip, capable of delivering up to 2x120W into 4Ω while maintaining low distortion and a 111dB signal-to-noise ratio, allowing it to drive demanding speakers without audible background noise. This current capability results in stable reproduction, maintaining clarity and control at higher listening levels. This approach is extended by the integration of a PFFB (Post-Filter Feedback) circuit, which corrects load-related variations at the output, allowing the frequency response to remain stable while ensuring consistent behavior regardless of the connected speakers.
Image showing the amplification chip of the FiiO Level 1
Image showing the Bluetooth chip of the FiiO Level 1
FiiO LEVEL 1: Connectivity and signal management
The integration of a Bluetooth 6.0 module compatible with LDAC enables high bitrate wireless reception, allowing direct playback from mobile sources while maintaining signal quality consistent with HiFi listening. This approach extends to wired connections with USB-C, coaxial and RCA inputs, allowing both digital and analog sources to be connected without unnecessary intermediate conversion. Internal processing supports streams up to 24bit 192kHz, enabling the use of high-resolution files without conversion limitations.
FiiO LEVEL 1: Outputs and system integration
The connection to speakers is handled via 4mm speaker terminals, ensuring direct power transfer to the drivers, while the presence of an RCA subwoofer output allows the addition of a subwoofer in a 2.1 configuration, improving low-frequency management without external filtering. This structure is extended with a pre-out output, allowing the device to be used as a preamplifier within an expandable system.
The unit can be controlled via its onboard buttons, such as those for bass and treble adjustment, or via the FiiO Control application.
Photo of the FiiO Level 1 integrated into an environment
Technical specifications
Product typePower amplifier
Inputs1x RCA
1x Coaxial
1x USB-C
Bluetooth 6.0
Outputs1x Speaker terminals
1x RCA subwoofer
1x Pre-out
Amplification chipTexas Instrument TPA3255
Bluetooth chipBluetrum BT8961
Bluetooth codecsSBC / LDAC
Supported sampling ratesUSB: PCM up to 24bits 96kHz
Coaxial: PCM up to 24bits 192kHz
Output power2x 120W @ 4 ohm, THD+N=1%, 48V
2x 115W @ 8 ohm, THD+N=1%, 48V
2x 300W @ 4 ohm, THD+N=1%, 53V
2x 240W @ 8 ohm, THD+N=1%, 53V
Frequency response5Hz-40kHz
SNR≥108dB
THD+N0.0025% @ 1kHz
Impedance4-8Ω
Power supply24-53V DC
Dimensions181 x 133 x 36mm
ColorBlack (Walnut)
Package contents1x FiiO LEVEL 1
1x Power cable
1x 48V 5A power adapter
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)120.0
Remote ControlControl app
Etonnant petit ampli
Petit par la taille, cet amplificateur est véritablement étonnant. Sa puissance est impressionnante et il alimente sans la moindre difficulté mes enceintes Visaton Studio, avec une aisance comparable à celle de mon précédent amplificateur Rega.
La qualité de restitution est également au rendez-vous. Le registre médium-aigu est particulièrement détaillé et naturel, tandis que la scène sonore offre une excellente spatialisation, procurant une écoute précise et agréable.
Ses nombreuses fonctionnalités en font un excellent amplificateur de bureau, à la fois performant, polyvalent et très agréable à utiliser au quotidien. Un produit qui dépasse largement ce que sa taille pourrait laisser imaginer.
This review has been posted for FIIO LEVEL 1 Integrated Amplifier Class D TPA3255 Bluetooth 6.0 LDAC 2x120W 4 Ohm Black
The FiiO LEVEL 1 is a Class D power amplifier designed to drive passive speakers within a compact stereo system. It delivers up to 2x 120W into...
