Class D amplifier 2x50W 4 Ohm - Bluetooth 5.0
The Fosi Audio BT10A is a small, compact and powerful Class D amplifier, offered at a contained price. Its amplification stage uses a TI TPA3116D2 chip, capable of developing a power of 2x50W under 4Ω with a high efficiency, while providing a clear and detailed sound reproduction.
The BT10A is simple and efficient, with 3.5mm stereo jack and Bluetooth 5.0 as inputs and gold-plated speaker terminals as outputs.
The front panel of the BT10A features a tone control that allows you to adjust the bass and treble levels to suit your audio system and preferences.
A Bluetooh code may be required to connect to the amplifier, this is "0000" or "1234".
Type of product | Stereo amplifier |
Type of amplification | Class D |
Inputs | 1x Jack 3.5mm stereo Bluetooth 5.0 |
Output | Speaker terminals |
Amplification chip | TI TPA3116D2 |
Power | 2x 50W @ 4Ω, 24V, 1% THD 2x 30W @ 8Ω, 24V, 1% THD 2x 35W @ 4Ω, 19V, 1% THD 2x 20W @ 8Ω, 19V, 1% THD |
Frequency response | 20Hz-20kHz (±1dB) |
THD | ≤ 0.04% |
SNR | ≥ 98dB |
Input sensitivity | 280mV |
Tone control | Bass / Treble |
Power supply voltage | 15 - 24VDC (AC adapter included) |
Dimensions (L*P*H) | 130x100x30mm |
Net weight | 650g |
Color | Black |
Package | 1x Fosi Audio BT10A 1x Power supply 19V 4.7A |
Input | Jack 3.5mm |
Input | Bluetooth |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3116D2 |
Power (W) | 50.0 |
Remote Control | No |
