The Fosi Audio BT30D is a 2.1-channel Class D amplifier capable of developing 2x50W + 100W power under 4 ohm thanks to two TI TPA3116D2 amplifier chips. It also features Bluetooth 5.0 functionality for stable, high-quality wireless reception. The front panel features no fewer than 5 potentiometers. The first three are for volume control as well as bass and treble equalization, while 2 others offer subwoofer frequency cutoff and subwoofer volume control. The rear panel features an RCA input, a speaker terminal output and two subwoofer outputs: one for passive subwoofer and one for active subwoofer. This small BT30D amplifier is ideal for setting up a 2.1-channel home theater system and enjoying immersive bass.
Inside the Fosi Audio BT30D amplifier are two TI TPA3116D2 amplifier chips, providing 2x 50W + 100W power at 4 ohms. That's a comfortable reserve of power for providing a 2.1-channel system.
In addition to its RCA input, the BT30D features a Bluetooth 5.0 reception chip, enabling you to use a phone or tablet to stream audio remotely.
| 1 | Power button |
| 2 | Input mode LED indicator |
| 3 | Subwoofer volume control |
| 4 | Subwoofer frequency cutoff |
| 5 | Treble equalization |
| 6 | Bass equalization |
| 7 | Volume control |
| 8 | Bluetooth antenna |
| 9 | RCA input |
| 10 | Active subwoofer output |
| 11 | Speaker terminals |
| 12 | Active subwoofer output |
| 13 | Power supply 12V-24V DC |
| Specifications | |
| Product type | Amplifiier |
| Channels | 2.1 |
| Amplification chip | TI TPA3116D2 |
| Inputs | 1x RCA stereo Bluetooth |
| Ouputs | Speaker terminals 1x Passive subwoofer output on speaker terminal 1x Active subwoofer output |
| Ouput power | 2x 50W + 100W |
| THD | ≤ 0.04% |
| SNR | ≥ 98dB |
| Frequency response | 20Hz-20kHz(±3dB) |
| Input sensitivity | ≤ 280mW |
| Termination impedance | 2-8 ohm |
| Subwoofer cutoff frequency | 20-200Hz |
| Bluetooth range | 15m unobstructed |
| General | |
| Power supply | 12V-24V |
| Dimensions | 118 x 132 x 35mm |
| Color | Black |
| Package | 1x Fosi Audio BT30D 1x 24V DC 4.5A power adapter with power cable 1x Bluetooth antenna |
| Input | RCA |
| Input | Bluetooth |
| Output | Speaker terminal |
| Output | RCA |
| Color | Black |
| Channel | 2.1 |
| Class | Class D / T |
| Amplifier chip | TPA3116D2 |
| Power (W) | 50.0 |
| Remote Control | No |
