Je suis surpris par la "puissance" délivrée par cette petite boite d'allumettes ! Bien évidemment, efficace pour faire bouger un sub à haut rendement et membrane papier par exemple. Il ne faudra pas non plus en exiger plus mais pour le prix....
The Fosi Audio M04 is a Class D amplifier based on a TPA3116 chip and capable of delivering 100W into 3 ohm. The M04 has an RCA input and a speaker terminal output. It can be used with speakers as a mono amplifier, thanks to its “PBTL” mode, or with a passive subwoofer, thanks to its “SUB” mode. A potentiometer on the front panel adjusts the subwoofer output crossover frequency from 20Hz to 200Hz. It is therefore ideal for users wishing to feed a subwoofer for immersive sound reproduction, or for users wishing to set up a dual-mono HiFi system.
Fosi Audio has chosen to use a TPA3116 amplifier chip in its M04 amplifier. This enables the M04 to develop up to 100W of power at 3 ohms.
The Fosi Audio M04 features a switch on the front panel to select between PBTL and SUB modes. PBTL mode enables it to power a passive loudspeaker, while SUB mode, as its name suggests, enables it to power a passive subwoofer. The M04 has an overall frequency response of 20Hz-20kHz (±3db), but a potentiometer lets you adjust the subwoofer cutoff frequency from 20Hz to 200Hz.
| 1 | Power LED indicator |
| 2 | Operating mode selection switch : PBTL/SUB |
| 3 | Subwoofer cutoff frequency control |
| 4 | Power button/Volume control |
| 5 | Analog input RCA Stereo |
| 6 | Output on speaker terminals (SUB/SPK) |
| 7 | DC 12-24V jack power port |
| Specifications | |
| Product type | Mono/subwoofer amplifier |
| Amplification chip | TI TPA3116 |
| Input | 1x stereo RCA |
| Output | 1x Speaker terminals |
| Output power | 100W @ 3 ohms |
| Minimum load | 2-8Ω |
| INput sensitivity | 600mv |
| SNR | ≥ 102dB |
| THD | ≤ 0.02% (1KHz, 1W) |
| Frequency response | 20Hz-20KHz (±3db) |
| Subwoofer output cut-off frequency setting | 20Hz-200Hz |
| General | |
| Power supply | 12-24V DC via DC jack (19V 4.74A power supply included) |
| Color | Black |
| Dimensions | 103x57x43mm |
| Weight | 175g |
| Package | 1x Fosi Audio M04 Mono/Sub Amplifier 1x 19V 4.74A power adapter |
| Input | RCA |
| Output | Speaker terminal |
| Color | Black |
| Channel | 1 (Mono) |
| Class | Class D / T |
| Amplifier chip | TPA3116 |
| Power (W) | 100.0 |
| Remote Control | No |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Julien L.
