FOSI MC351 Class D Amplifier
The Fosi Audio MC351 integrated amplifier is a small all-in-one amplifier featuring two TI TPA3255 amplifier chips, enabling it to deliver up to 2x165W+350W of power at 4 ohms. This makes it possible to set up a 2.1-channel system for an immersive listening or TV experience with deep bass. A built-in DAC gives it the benefit of digital and optical inputs such as a USB-C input (24bit/96kHz), a Toslink optical input and a coaxial SPDIF input (24bit 192kHz).
Reference : 19496
199,00 €tax incl.
165,83 € tax excl.
Fosi MC351 Class D Amplifier 2.1 Channel Bluetooth 5.3 2xTPA3255 2x165W+350W @ 4 ohm
Fosi MC351 picture
The Fosi Audio MC351 integrated amplifier is a small all-in-one amplifier featuring two TI TPA3255 amplifier chips, enabling it to deliver up to 2x165W+350W of power at 4 ohms. This makes it possible to set up a 2.1-channel system for an immersive listening or TV experience with deep bass. A built-in DAC gives it the benefit of digital and optical inputs such as a USB-C input (24bit/96kHz), a Toslink optical input and a coaxial SPDIF input (24bit 192kHz). Digital inputs are complemented by Bluetooth 5.3 functionality supporting standard SBC and AAC codecs, as well as an analog RCA stereo input. The front panel features three potentiometers for volume, bass and treble control, as well as a small round Vumeter for an aesthetically pleasing vintage effect. A button also makes it easy to select the desired input source. A 32V/5A power supply completes the package.
The 32V/5A power supply supplied cannot match the MC351's power claims. A 48V/5A power supply (sold separately) is required.
Fosi MC351: a considerable power reserve
The MC351's two TI TPA3255 amplifier chips enable it to develop an output power of up to 2x165W at 4 ohms on its speaker terminals, and 350W at 4 ohms on its subwoofer output. One of the MC351's major advantages lies in its ability to offer this level of power and a subwoofer output on terminals. All this while maintaining a THD ≤ 0.03% and an SNR ≥ 100dB.
Photo des puces TPA3255
Photo de la face arrière du Fosi MC351
Fosi MC351: integrated DAC
The integration of a DAC chip in the MC351 allows it to benefit from several digital and optical inputs in addition to its analog RCA input. This DAC chip supports sampling rates up to PCM 24bit 96kHz on its USB input and 24bit 192kHz on its Toslink optical input and coaxial SPDIF input.
Fosi MC351: Bluetooth 5.3
The MC351 benefits from Bluetooth reception, and supports standard SBC and AAC codecs. A valuable feature for quick and easy use with a smartphone or tablet, for example. The Bluetooth 5.3 standard guarantees low-latency wireless transmission.
Bluetooth 5.3
Photo d'un condensateur 4700μF
Fosi MC351: a clean power supply
Two 4700μF capacitors guarantee a stable power supply to the MC531's circuits. This not only improves the final sound reproduction, but also enhances the MC351's durability.
Fosi MC351: a complete interface
Photo of the complete Fosi mc351 interface
1Bluetooth antenna
2Vumeter
3Input indication LED
4Source selector
5Treble control
6Bass control
7Volume control
8Pre-out jack 3.5mm
9Bluetooth antenna connector
10Stereo RCA input
11Coaxial input
12Toslink optical input
13USB-C input
14Right channel output on speaker terminal block
15Left channel output on speaker terminal block
16Passive subwoofer output on terminal block
1724-48V DC power supply
Product typeIntegrated amplifier
Amplification typeClass D
Channel2.1 channel
Amplification chipTI TPA3255
Inputs1x RCA analog stereo
1x USB-C
1x SPDIF coaxial
1x Optical Toslink
Bluetooth
OutputsSpeaker terminals
1x Passive subwoofer output on terminal block
1x Pre-out on 3.5mm jack
Output power2x 165W @ 4 ohm
Subwoofer output power350W @ 4 ohm
Subwoofer output frequency20Hz-250Hz
Termination impedance4-8 ohm
Frequency response20Hz-20KHz (±0.1dB)
THD≤0.03%
SNR≥100dB
Supported sample ratesUSB: 24bit/96kHz
Toslink optical and SPDIF coaxial: 24bit/192kHz
Bluetooth standardBluetooth 5.3
Suppported Bluetooth codecsSBC et AAC
Bluetooth range10m obstacle-free
Tone controlBass and treble
Power supply24/48V DC (32V 5A supplied)
Dimensions330.6 x 228.6 x 76.2mm
ColorGray
Package1x Fosi Audio MC351 amplifier
1x Bluetooth antenna
1x USB-A to USB-C cable
1x Toslink optical cable
1x 32V 5A DC power adapter
OutputSpeaker terminal
OutputSubwoofer
OutputJack 3.5mm
ColorGray
Channel2.1
Amplifier chipTPA3255
Power (W)350.0
Power (W)165.0
FOSI MC351 Class D Amplifier 2.1 Channel Bluetooth 5.3 2xTPA3255 2x165W+350W @ 4 ohm
The Fosi Audio MC351 integrated amplifier is a small all-in-one amplifier featuring two TI TPA3255 amplifier chips, enabling it to deliver up to...
