O-NOORUS D1 PRO Amplifier
The O-Noorus D1 Pro is a Class D amplifier based on a TPA3255 chip, OPA1656 op-amps, and a PFFB (Post Filter Feedback) architecture, allowing it to cleanly deliver up to 2x230W @ 4 ohms (10% THD+N, with a 48V 10A power supply).
Reference : 21609
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 19-11-2026.
O-Noorus D1 Pro Class D Amplifier TPA3255 PFFB 2x90W 4 Ohm
Photo of the O-NOORUS D1 PRO
The O-Noorus D1 Pro is a Class D amplifier based on a TPA3255 chip, OPA1656 op-amps, and a PFFB (Post Filter Feedback) architecture, allowing it to deliver up to 2x89W under 4 ohms (10% THD+N, with a 36V 5A power supply). The D1 Pro benefits from numerous operating modes and settings: high-pass filter, low-pass filter, and 3-band equalizer. In terms of connectivity, the D1 Pro includes the essentials with an RCA analog input and speaker terminal outputs, complemented by a subwoofer output for building a 2.1 channel system as well as a 3.5mm pre-out jack. The D1 Pro comes with a remote control and a 36V 5A power supply.
PCB of the O-NOORUS D1 PRO
O-Noorus D1 Pro: PFFB TPA3255 circuit
The combination of the PFFB circuit, the TPA3255 chip, and OPA1656 op-amps Provides clean signal Processing and power up to 2x89W at 4 ohms. Furthermore, the OPA1656 op-amps are integrated in DIP8 format for easy replacement.
O-NOORUS D1 PRO: PFFB TPA3255 circuit
O-Noorus D1 Pro: 3-band EQ
The D1 Pro includes a 3-band tone control (Treble/Mid/Bass) for tailored sound adjustment. Each frequency band level is adjustable within a ±12dB range using the remote control.
O-NOORUS D1 PRO: 3-band EQ
O-Noorus D1 Pro: High-pass filter
The high-pass filter allows you to set the cutoff frequency of the signal at the D1 Pro speaker terminals. Available cutoff frequencies are 60Hz, 80Hz, 100Hz, and 120Hz, but it is also possible to bypass this function.
O-NOORUS D1 PRO: high-pass filter
O-Noorus D1 Pro: Low-pass filter
The low-pass filter allows you to set the cutoff frequency of the LPF output for an active subwoofer. Selectable -3dB cutoff frequencies are 40Hz, 60Hz, 80Hz, or 100Hz.
O-NOORUS D1 PRO: Low-pass filter
Overview of the O-Noorus D1 Pro
Overview of the O-NOORUS D1 PRO
1Subwoofer output
2RCA Input
33.5mm jack pre-out
4Speaker terminal output
524-48V Power Input via DC Jack
Technical specifications
Product typeAmplifier
Amplification typeClass D
Amplifier chipTPA3255
Op-amps2x OPA1656 (DIP8)
Inputs1x Stereo RCA
OutputsSpeaker terminals
1x Subwoofer output
1x 3.5mm pre-out jack
Output power2x 230W @ 4 ohm (48V 10A THD+N<10%)
2x 195W @ 8 ohm (48V 10A THD+N<10%)
2x 115W @ 4 ohm (48V 5A THD+N<10%)
2x 103W @ 8 ohm (48V 5A THD+N<10%)
2x 89W @ 4 ohm (36V 5A THD+N<10%)
2x 82W @ 8 ohm (36V 5A THD+N<10%)
THD≤ 0.005%
SNR≥ 91dB @ 4Ω, 1KHz, 5W
SINAD90dB @ 4Ω, 1kHz, 5W
Load impedance2-8Ω
Frequency response20Hz-20kHz
Power supply24V-48V DC (36V 5A included power supply)
Dimensions120 x 170 x 38mm
Weight0.650kg
Package contents1x O-Noorus D1 Pro
1x Remote control
1x DC 36V/5A power supply
Measurements of the O-NOORUS D1 PRO
OutputJack 3.5mm
OutputSpeaker terminal
OutputSubwoofer
Speaker Power (W RMS)90.0
Channel2.1
Power (W)90.0
Remote ControlYes
O-NOORUS D1 PRO Amplifier Class D TPA3255 PFFB 2x90W 4 Ohm
The O-Noorus D1 Pro is a Class D amplifier based on a TPA3255 chip, OPA1656 op-amps, and a PFFB (Post Filter Feedback) architecture, allowing it to...
