By buying this product you get 25 loyalty points
The O-Noorus D3 Pro is a powerful integrated amplifier based on numerous audiophile components. Its amplification stage features a TPA3255 chip and a PFFB structure with NJW1194 volume control, while its digital-to-analog conversion stage features an XMOS XU316 USB interface coupled with an AKM AK4493SEQ chip. The D3 Pro is therefore capable of supporting sampling rates up to PCM 32bit 768kHz and DSD512 while maintaining an SNR of 105dB and delivering up to 2x225 under 4 Ohms. This small amplifier can therefore fill a large space with sound from a high-definition source, much to the delight of pure audio enthusiasts. Added to this is a QCC3084 Bluetooth chip for stable reception of aptX Lossless, LDAC, and LC3 codecs. In terms of connectivity, it is not to be underestimated, with two USB-C inputs (USB Audio and USB Host), an HDMI ARC input, two coaxial and optical Toslink SPDIF inputs, an RCA line input/output, and a subwoofer output to top it all off. The D3 therefore offers the possibility of setting up a 2.1-channel home theater system to enjoy your favorite movies in addition to its HiFi functionality.
For high efficiency, low power consumption, and high signal processing capabilities.
Offers low-distortion signal processing with excellent dynamics and an SNR of up to 125dB.
Allows volume control while avoiding excessive distortion or noise.
Offers high power output up to 2x225W sous 4 ohms.
The D3 Pro features a QCC3084 Bluetooth receiver chip that supports high-definition codecs up to aptX Lossless, LDAC, and LC3 for reliable and stable wireless transmission. This allows you to enjoy high-resolution files via a streaming platform, for example.
In terms of connectivity, an HDMI ARC input and a subwoofer output with low-pass filter (adjustable from 40-200Hz) allow the O-Noorus D3 Pro to set up a 2.1-channel system. This means you can enjoy powerful, immersive bass for both HiFi and home theater use.
The RCA line input is converted to an RCA line output when not in use thanks to the source sharing mode. This can be very useful for connecting another amplifier, for example.
| 1 | RCA multiplex line input/output |
| 2 | Subwoofer output |
| 3 | Coaxial input |
| 4 | USB-C Input (USB Audio) |
| 5 | HDMI ARC input |
| 6 | USB-C input (USB Host) |
| 7 | Bluetooth antenna |
| 8 | Toslink optical input |
| 9 | Speaker terminal output |
| 10 | Power supply via 24V-48V DC jack |
This Class D integrated amplifier offers a lot of features. It's nice to see such competent implementations as those found in the D3 Pro. Compared to most of its competitors, it stands out with its comprehensive set of inputs and remote control. Its measured performance is very good for its class, but given its price, I would have liked to see better PFFB.
Technical characterisrics
| Specifications | |
| Product type | Integrated amplifier |
| Amplification chip | TPA3255 |
| USB interface | XMOS XU-316 |
| DAC chip | AK4493SEQ |
| Volume control chip | NJW1194 |
| Bluetooth chip | QCC3084 |
| Inputs | 1x RCA line input/output 1x USB-C (USB Audio) 1x USB-C (USB Host) 1x HDMI ARC 1x Coaxial 1x Toslink optical Bluetooth |
| Outputs | Speaker terminals 1x RCA line input/output 1x Subwoofer output |
| Supported sample rates | USB: PCM up to 32bit 768 kHz, DSD up to DSD512 Coaxial and Toslink optical: PCM up to 24bit 192 kHz |
| Supported Bluetooth codecs | SBC, AAC, aptX Lossless, LDAC, LC3 |
| Output power | 2x225W @ 4 ohm |
| THD+N | < 0.0028% |
| SNR | ≥ 92dB |
| SINAD | 91dB |
| General | |
| Power supply | Power supply via DC 24V-48V jack (48V 5A power supply unit included) |
| Dimensions | 170 x 120 x 35mm |
| Weight | 0.550kg |
| Package | 1x O-Noorus D3 Pro Amplifier 1x USB-A to USB-C cable 1x USB-A to USB-C adapter 1x Remote control 1x Bluetooth antenna 1x 48V 5A Power adapter |
| Input | HDMI ARC |
| Input | USB |
| Input | SPDIF |
| Input | Bluetooth |
| Input | RCA |
| Input | Optical |
| Output | Speaker terminal |
| Output | RCA |
| Output | Subwoofer |
| Color | Black |
| Channel | 2.1 |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TPA3255 |
| Power (W) | 300.0 |
| Remote Control | Yes |
