O-NOORUS D4 Amplifier
The O-Noorus D4 II is a powerful integrated amplifier, based on high-quality components. It incorporates an ES9023P DAC chip, a TPA3255 amplifier chip and DIP8-mounted OPA1642 OPAs. As a result, the D4 II supports PCM up to 24bit 192kHz via its various digital inputs, and delivers up to 2x260W into 4 ohms, enabling it to soundtrack a sizeable space.
Reference : 20647
139,00 €tax incl.
115,83 € tax excl.
O-Noorus D4 IIClass D 2.1 Amplifier TPA3255 PFFB Bluetooth 5.3 2x220W 4 Ohm
Photo du O-NOORUS D4
The O-Noorus D4 II is a powerful  integrated amplifier based on high-quality components. It features an ES9023P DAC chip, a TPA3255 amplifier chip and OPA1642 op-amps in DIP8 format. The D4 II supports PCM up to 24bit 192kHz via its various digital inputs and delivers up to 2x220W into 4 ohms, allowing it to drive large spaces. In addition, Bluetooth 5.3 provides convenient and reliable wireless reception. Connectivity covers the essentials, with the addition of an HDMI ARC input and a subwoofer output for an immersive 2.1-channel system. Versatile, the O-Noorus D4 II will satisfy both Hi-Fi enthusiasts and 2.1 home theater users.
O-Noorus D4 II : A powerful amplifier
The amplification stage of the O-Noorus D4 II is based on a PFFB (Post-Filter FeedBack) circuit, a TPA3255 chip and OPA1642 op-amps. It is capable of delivering up to 2x220W into 4 ohms (THD+N 1%). The O-Noorus D4 II can easily drive demanding speakers and fill large spaces. Furthermore, the OPA1642 op-amps are in DIP8 format and easily replaceable.
Circuit d'amplification du O-NOORUS D4
La puce DAC du O-NOORUS D4
O-Noorus D4 II : ES9023P DAC
The DAC chip allows the O-Noorus D4 II to decode PCM up to 24bit 192kHz via HDMI ARC, optical Toslink and coaxial inputs, while the USB input supports CD quality 16bit 48kHz. The O-Noorus therefore allows you to enjoy high-resolution sources for quality listening.
O-Noorus D4 II : Bluetooth 5.3
The O-Noorus D4 II can receive an audio signal wirelessly thanks to Bluetooth 5.3 with support for SBC and AAC codecs.
La fonctionnalité Bluetooth du O-NOORUS D4
Expérience home cinéma avec le O-NOORUS D4
O-Noorus D4 II : Immersive TV experience
The HDMI ARC port allows you to use a television or a video game console as a source. In addition, the subwoofer output enables an immersive sound experience.
O-Noorus D4 II : 3-band EQ
The 3-band equalizer provides precise adjustment for tailoring the sound rendering according to the user’s preferences or the music being played.
O-Noorus D4 II : EQ 3 bandes
Overview of the O-Noorus D4 II
Aperçu du O-NOORUS D4 II
1Power ON/OFF + Bypass / Tone mode selection
2Source/volume indicator
3Bass control
4Midrange control
5Treble control
6Volume / Source selection
7RCA input
8Bluetooth antenna
9Subwoofer output
10SPDIF coaxial input
11Balanced 4.4mm jack input
12HDMI ARC input
13USB-C input
14Optical Toslink input
15Speaker terminals
16Power input via DC jack
Technical specifications
Product typeIntegrated amplifier
Amplifier typeClass D
Amplification componentTPA3255
Op-ampsOPA1642
DAC chipES9023P
Inputs1x USB-C
1x HDMI ARC
1x Coaxial
1x Optical Toslink
1x RCA stereo
1x Balanced 4.4mm jack input
Bluetooth 5.3
OutputsSpeaker terminals
Subwoofer output
Supported sample ratesUSB: PCM up to 16bit 48kHz
Other digital inputs: PCM up to 24bit 192kHz
Output power2x 220W @ 4 ohm (THD 1%, 48V 10A)
2x 160W @ 8 ohm (THD 1%, 48V 10A)
2x 120W @ 4 ohm (THD 1%, 48V 5A)
2x 95W @ 8 ohm (THD 1%, 48V 5A)
Load impedance2-8Ω
Frequency response20Hz-20kHz
RCA/XLR inputs
THD+N @ 1kHz<0.003% @4 ohm 5W
<0.002% @8 ohm 5W
SNR @MAXOUT 1kHz105dB
Gain32dB
Noise130uVrms
SINAD @ 5W92dB
Digital inputs
THD+N @ 1kHz<0.04% @4 ohm 5W
<0.04% @8 ohm 5W
SNR @MAXOUT 1kHz95dB
Gain32dB
Noise860uVrms
SINAD @ 5W78dB
Power supply24V-48V (36V 5A power supply included)
Dimensions180 x 158 x 40mm
Weight710g
Package1x O-Noorus D4 II
1x Bluetooth antenna
1x USB-C to USB-A cable
1x USB-A to USB-C adapter
1x 36V 5A power supply
Mesures du O-Noorus D4 II
InputHDMI ARC
OutputSubwoofer
OutputSpeaker terminal
Channel2.1
Amplifier chipTPA3255
Power (W)260.0
Remote ControlYes
O-NOORUS D4 II Amplifier Class D 2.1 TPA3255 PFFB Bluetooth 5.3 2x220W 4 Ohm
The O-Noorus D4 II is a powerful integrated amplifier, based on high-quality components. It incorporates an ES9023P DAC chip, a TPA3255 amplifier...
