SMSL AO300 PRO Amplifier Headphone Amplifier DAC Black
With the AO300 Pro, SMSL unveils an improved version of its DAC, amplifier and headphone amplifier. Powerful and high-quality, it incorporates high-end components: a MA5332MS Class D amplifier chip, a CS43131 DAC chip and an XMOS XU316 USB interface. These components enable it to decode up to 32-bit 768kHz PCM, DSD up to DSD256 and MQA. In terms of amplification performance, the AO300 Pro is capable of delivering up to 2x165W into 4Ω and 2x85W into 8Ω with a THD+N of only 0.003%.
By buying this product you get 27 loyalty points
Reference : 21318
279,00 €tax incl.
232,50 € tax excl.
SMSL AO300 Pro Class D Amplifier MA5332MS Headphone Amplifier DAC CS43131 2x165W 4Ω 32bit 768kHz DSD256 MQA Black
SMSL AO300 Pro : Front view
With the AO300 Pro, SMSL unveils an improved version of its DACamplifier and headphone amplifier. Powerful and high-quality, it incorporates high-end components: a MA5332MS Class D amplifier chip, a CS43131 DAC chip and an XMOS XU316 USB interface. These components enable it to decode up to 32-bit 768kHz PCM, DSD up to DSD256 and MQA. In terms of amplification performance, the AO300 Pro is capable of delivering up to 2x165W into 4Ω and 2x85W into 8Ω with a THD+N of only 0.003%. Versatile, it features a comprehensive and varied range of connections and incorporates a Bluetooth 5.3 receiver, an HDMI eARC input port and a subwoofer output for a more immersive 2.1-channel experience. A balanced 4.4mm headphone output and a 6.35mm headphone output are also located on the front panel.
SMSL AO300 Pro : summary of features
Des composants High-end pour des performances élevées
SMSL AO300 Pro : amplification chip
MA5332MS amplification chip
The MA5332MS is a Class D stereo amplifier chip. This MCM (multi-chip module) solution integrates 4 MOSFET transistors. It enables the A0300 to deliver power up to 2x165W under 4Ω and 2x85W under 8Ω.
SMSL AO300 Pro : Puce DAC
CS43131 DAC chip
The Cirrus Logic CS43131 chip is a DAC chip integrating a low-noise, high-fidelity headphone amplifier. In fact, this chip is capable of driving audiophile headphones with an impedance of 600Ω and an output power of 5mW per channel. With a 32Ω load, it delivers 32mW per channel.
SMSL AO300 Pro : Puce XMOS
The AO300's USB-C input is complemented by XMOS's flagship XU316 interface. This enables it to support high-resolution audio streams up to PCM 32bit 768kHz and DSD up to DSD256.
SMSL AO300 Pro: Bluetooth 5.3 functionality
The AO300 Pro features a Bluetooth 5.3 receiver chip and supports high-resolution aptX HD and LDAC codecs. This allows you to easily enjoy audio sources such as your smartphone for remote use.
SMSL AO300 Pro : Bluetooth 5.3
SMSL AO300 Pro : connected to a television
SMSL AO300 Pro: HDMI eARC and subwoofer output
For the AO300 Pro model, SMSL has included an HDMI eARC input, allowing volume control and synchronised power-up with a CEC-compatible television. In addition, there is a subwoofer output to transform your Hi-Fi system into a 2.1-channel system and achieve immersive sound with an active subwoofer. The AO300 Pro from SMSL can therefore serve as a small home cinema amplifier.
SMSL AO300 Pro: MQA
The AO300 Pro's Toslink and coaxial optical inputs support MQA and MQA-CD (Master Quality Authenticated) streams thanks to an MQA decoder, allowing you to enjoy the richest and most detailed sound reproduction possible. This amplifier/DAC therefore offers the possibility of enjoying professional audio quality with a reproduction that is as close as possible to the original sound recorded and processed in the studio.
SMSL AO300 Pro : on a table
SMSL AO300 Pro: Remote control
The AO300 comes with a remote control offering a full range of functions. It includes the basic play/pause/previous/next functions, volume control, and access to the menu and source selection.
Presentation of the SMSL AO300 Pro
SMSL AO300 Pro : numbered diagram
1Screen
2Volume knob
36.35mm headphone jack output
4Balanced headphone output 4.4mm jack
5RCA stereo input
6Coaxial input
7Bluetooth antenna connector
8Toslink optical input
9Power button
10Subwoofer output
11USB-C input
12HDMI eARC input
13Speaker terminals
Product typeAmplifier
DAC
Headphone amplifier
DAC chipCS43131
Amplifier chipMA5332MS
USB interfaceXMOS XU316
Inputs1x Stereo RCA line input
1x Coaxial
1x Toslink optical
1x USB-C
1x HDMI eARC
Bluetooth
OutputsSpeaker terminals
1x Subwoofer output
1x 4.4mm balanced headphone jack output
1x Single-ended 6.35mm headphone output
Output power2x 165W @ 4Ω
2x 85W @ 8Ω
Total harmonique distorsion more noise (THD+N)0.003%
Signal-to-noise ratio (SNR)107dB
Channel separation98dB
Input sensitivity / Input impedance280mV / 22kΩ
USB transmission typeUSB 2.0 Asynchrone
USB compatibilityWindows 7/8/9/10/11
Mac OSX
Linux
Supported sampling ratesUSB : PCM 32bit 768kHz, DSD256 et MQA
Optique / Coaxial : PCM 24bit 192kHz, DSD64 (DoP) and MQA-CD
Power consumption40W (with normal volume)
Dimensions219 x 42 x 185mm
Weight1.5kg
Package1x SMSL AO300 Pro
1x Remote control
1x Power cable
1x USB-A to USB-C cable
1x HDMI cable
1x Bluetooth antenna
InputHDMI eARC
OutputJack 6.35mm
OutputJack 4.4mm
OutputSpeaker terminal
OutputSubwoofer
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rateMQA
Max sampling rate768kHz
Channel2.1
Amplifier chipInfineon MA5332M
Power (W)165.0
Remote ControlYes
SMSL AO300 PRO Class D Amplifier MA5332MS Headphone Amplifier DAC CS43131 2x165W 4Ω 32bit 768kHz DSD256 MQA Black
With the AO300 Pro, SMSL unveils an improved version of its DAC, amplifier and headphone amplifier. Powerful and high-quality, it incorporates...
