SMSL PA400 Stereo / Mono Amplifier
The SMSL PA400 is an innovative amplifier that uses Gallium Nitride (GaN) transistors to deliver 2x250W amplification at 4Ω. Its versatility also allows it to operate in pure mono mode, delivering an impressive 500W at 8Ω. Each component of the PA400 has been meticulously selected to achieve exceptional audio performance, with an incredibly low harmonic distortion rate of 0.0003% and a signal-to-noise ratio of 115dB.
By buying this product you get 55 loyalty points
Reference : 21241
555,00 €tax incl.
462,50 € tax excl.
Shipping date: 19-05-2026.
SMSL PA400 Stereo / Mono Amplifier Infineon GaN 2x250W 4 Ohm / 1x500W 8 Ohm
SMSL PA400 : Front view
SMSL PA400: GaN transistors amplification
The PA400 uses GaN FET transistors for its amplification stage. These transistors offer significantly higher efficiency than traditional silicon transistors, minimising energy losses during switching and thus reducing heat generation. In addition, GaN transistors are distinguished by their extremely high switching speed, in the order of 1MHz. This increased speed has several notable advantages: it eliminates switching noise in the circuits, significantly reducing background noise, and it allows for much faster response times, instantly adapting to variations in power demand for greatly improved audio dynamics.
SMSL PA400 : difference entre transistor au silicium et à la nitrure de gallium
SMSL PA400: Optimised power supply
The PA400 incorporates a switching power supply stage specially designed for demanding audio applications. This power supply is capable of delivering considerable power while maintaining perfectly silent operation. For added safety, the PA400 is equipped with overheating and overpower protection circuits.
SMSL PA400 : Power supply
SMSL PA400 : Terminal blocks
SMSL PA400: Gold-plated output connectors
The PA400's output connectors are gold-plated to effectively protect them from oxidation and corrosion, while ensuring excellent electrical conductivity for optimal, loss-free audio signal transmission.
SMSL PA400 overview
SMSL PA400 : Product overview
1Control knob
2Power indicator light
3Remote control receiver
4Screen
5Right speaker output (stereo)
6Left speaker output (stereo)
7IEC socket
8Speaker output + (mode)
9Speaker output - (mode)
10Single-ended stereo RCA input
11Balanced stereo XLR input
12Mono XLR input
Product typeIntegrated amplifier
Amplification componantInfineon GaN FET transistors
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
1x Mono XLR
OutputSpeaker terminal
Total harmonic distortion more noise (THD+N)0.003%
Signal-to-noise ratio (SNR)115dB
Channel separation75dB
Input sensitivityRCA stéréo : 0.96Vrms/22kΩ
XLR stéréo : 2.1Vrms/22kΩ
XLR mono : 2.7Vrms/22kΩ
Stereo output power2x 250Wrms @ 4Ω
2x 200Wrms @ 8Ω
Mono output power1x 500Wrms @ 8Ω
Volume control chipPGA2311
Power supply100-240V AC
Energy consumptionStandby : < 0.5W
In use : 40W
Dimensions254 x 47.7 x 242mm
Weight2.58kg
ColorWhite
Package1x SMSL PA400
1x Remote control
1x Power cable
InputXLR
ColorWhite
Channel2 (Stereo)
Channel1 (Mono)
ClassN/A
Amplifier chipTransistors
Power (W)500.0
Power (W)250.0
Remote ControlYes
Download
The SMSL PA400 is an innovative amplifier that uses Gallium Nitride (GaN) transistors to deliver 2x250W amplification at 4Ω. Its...
