TOPPING MINI300 Integrated Amplifier Black
The Topping Mini300 is a Class D stereo amplifier delivering 2x125 W into 4Ω in a fully balanced, high-efficiency design. Its 124dB SNR, background noise below 15µV and -106dB crosstalk ensure faithful reproduction of the original sound. Housed in an aluminium chassis and equipped with a 12V trigger, it combines performance, compactness and reliability, with built-in protection against overheating and overload.
Reference : 21257
138,66 €tax incl.
115,55 € tax excl.
Shipping date: 17-11-2026.
Topping MINI300 Balanced Integrated Amplifier Class D 2x125W 4 Ohm Black
Topping MINI300 : Front view
Topping Mini300: A balanced Class D amplifier
The Topping Mini300 is a compact stereo amplifier delivering 2x125 W into 4Ω, designed to offer controlled power in a small format. Its Class D topology ensures high energy efficiency and excellent thermal stability, while the fully balanced design guarantees rigorous channel separation and reduced background noise.
The aluminium chassis enhances heat dissipation and protects the internal circuits from electromagnetic interference. A 12V trigger input also facilitates the integration of the Mini300 into an existing music system or home cinema.
Topping MINI300 : White, black and grey version
Topping Mini300: Outstanding audio performance
The architecture of the Mini300 is based on a selection of low-distortion components, optimised for transparency and precision. The amplifier has a signal-to-noise ratio of 124dB, background noise of less than 15µV and a harmonic distortion rate of < 0.0005%, ensuring faithful reproduction at any volume level.
Topping MINI300 : THD+N
The -106dB crosstalk ensures clear channel separation, preserving the stereo image and spatial coherence of the recording. This performance reflects an approach focused on neutrality and stability, without sound colouration.
Topping MINI300 : GX output and connector
Topping Mini300: Protection and reliability
Designed for long-term use, the Mini300 incorporates several protection circuits against overheating and overcurrent, ensuring stable operation over time, even during prolonged listening at high volumes.
Its combination of performance, compactness and quiet operation makes it an amplifier that is precise, efficient and easy to integrate into a modern hi-fi system.
Topping Mini 300 test by Audio Science Review
"The Topping Mini 300 offers meticulous workmanship with excellent implementation of Class D chip-based amplification. For an affordable price, you get a stereo amplifier that produces a lot of power while taking up very little space. It certainly breaks the cliché that you have to spend a lot of money to get good performance. I highly recommend the Topping Mini 300 stereo amplifier."
Technical specifications
Product typeAmplificateur intégré
Inputs1x Single-ended stereo RCA
1x Balanced stereo Jack 6.35mm
OutputSpeaker terminal
Output power2x140W @ 4Ω THD+N<10%
2x125W @ 4Ω THD+N<1%
2x85W @ 8Ω THD+N<10%
2x65W @ 8Ω THD+N<1%
Load impedance4-8Ω
12V trigger
Single-ended input specifications
Total harmonic distortion more noise (THD+N)< 0.0006% @ 4Ω 5W
< 0.0008% @ 8Ω 5W
Signal-to-noise ratio (SNR)121dB
Dynamic range121dB
Frequency response20Hz-40kHz (±0.3dB)
Output level65Vpp @ 4Ω
68Vpp @ 8Ω
Noise< 15uVrms
Crosstalk-90dB
Input sensitivity1.3Vrms
Gain25dB
Channel balance0.1dB
Balanced input specifications
Total harmonic distortion more noise (THD+N)< 0.0005% @ 4Ω 5W
< 0.0004% @ 8Ω 5W
Signal-to-noise ratio (SNR)124dB
Dynamic range124dB
68Vpp @ 8Ω
Noise< 15uVrms
Crosstalk-106dB
Input sensitivity2.6Vrms
Gain19.2dB
Power supply voltage38V DC
Package1x Topping Mini300
1x 38V mains adapter (2-pin GX connector)
Topping MINI300 : Measures
InputJack 6.35mm
Channel2 (Stereo)
Amplifier chipN/A
Power (W)125.0
4 reviews
Ampli neutre de qualité.
Bon petit ampli de classe D, neutre et assez puissant pour une pièce de 28 m2. Il ne sonne pas trop clinique, comme par exemple le Aiyima A70. Équipement: Dac Topping E70V, enceintes Elipson XLS 7. Un preamp DIY avec nutube Korg est placé devant, ce qui me permet d'avoir une sortie sub (Focal 600P), mais même sans le préamp, il sonne bien.
This review has been posted for TOPPING MINI300 Balanced Integrated Amplifier Class D 2x125W 4 Ohm Black
Huge upgrade for my desktop setup
I was really surprised by what such a small Class D chip amplifier can do. I wanted more desk space, and this device beats my older Class A/B amplifier in every way. Using a PC as the source and a Topping DX3 Pro+ as a preamp, it delivers plenty of power for home listening, easily driving my Monitor Audio Silver RS1 speakers (which have a sensitivity of 90 dB at 1W/1m). Transients are reproduced very sharply, and the bass reproduction is also tight. So, this is a big upgrade for my setup. The amplifier is very linear and dynamic, with a black background (no background noise). Excellent price-to-quality ratio. Highly recommended 5/5.
Essais depuis cet après midi
Pour ceux qui hésitent sur le mini300 Je vous conseille la consultation des test d'un américain sympa celui là ... faire cette recherche sur Firefox: topping mini 300 review samir . Pour ma part j'ai découvert cet ampli il y a 2jours et mon choix à été bien facilité par cet expert de l'oscilloscope et du matériel hifi passionné . Monté en symétrique avec des cordons xlr/trs avec un Dac Smsl RAW-MDA1 et des enceintes JMR Lucia et cet ampli à sa place au milieux ils se régalent des Flac 24/192/96 et même de mp3. C'est effectivement un appareil extra-ordinaire et vraiment à un prix ... (l'alimantation fait partie de l'emballage!.) Entre Amazon et Audiophonics je n'hésiterais plus pour ce type de matériel. Merci à vous d'être aussi rapide et d'exister
Un superbe ampli
Un superbe ampli qui drive à merveille mes Klipsch RP-280F. Une belle réserve de puissance et un son excellent pour un prix mini. Seul bémol, pas de télécommande, sinon il aurait été parfait
The Topping Mini300 is a Class D stereo amplifier delivering 2x125 W into 4Ω in a fully balanced, high-efficiency design. Its 124dB SNR,...
