SMSL SA300 Class D Amplifier USB Bluetooth 5.0 aptX Subwoofer MA12070 2x80W 4 Ohm 32bit 384kHz
Although it has a compact format, this SMSL SA300 amplifier is able to deliver a comfortable 2x80W power at 4 ohm with high efficiency.  The SA300 is a digital amplifier, which has a Micro USB input and Bluetooth transmission.
4.7 / 5
Reference : 14233
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 27-05-2026.
SMSL SA300
Class D Amplifier USB Bluetooth 5.0 aptX Subwoofer MA12070 2x40W 8Ω 32bit 384kHz
SMSL SA300 Amplificateur Class D USB Bluetooth 5.0 aptX Subwoofer MA12070 2x40W 8Ω 32bit 384kHz
Although it has a compact format, this SMSL SA300 amplifier is able to deliver a comfortable 2x40W power at 8Ω with high efficiency.  The SA300 is a digital amplifier, which has a Micro USB input and Bluetooth transmission.
Infineon MA12070 Amplification chip
The SMSL SA300 uses the new German Infineon MA12070 amplifier chip. This one, capable of delivering up to 2x80W under 4Ω also benefits from a Class D architecture allowing a high efficiency of up to 92%. This chip offers a pure, precise and rich reproduction.
Another strong point of this SMSL SA300 is its Bluetooth transmission. It is equipped with a Bluetooth chip that allows you to stream your music directly from your smartphone or any other transmitting device. The chip supports Bluetooth version 5.0 and the aptX transmission codec, allowing a close listening to CD quality.
Connectivity
On the connector side, the SA300 is both simple and efficient. It includes Bluetooth and an analog RCA stereo input as well as the Micro USB input. At the output the amplifier offers speaker terminals and a Subwoofer output on an RCA connector. All connectors (except the Micro USB port) are gold plated for improved conductivity and good oxidation resistance.
xxx
1Screen
2ON/OFF Button
3Input selection
4Volume button
5Speaker output
6RCA line input
7Subwoofer output
8Bluetooth antenna
9Power supply (24V DC)
10Micro USB input
Filters & Equalization
The amplifier includes 8 predefined filters to adapt the sound reproduction to your listening and audio system. It is also possible to adjust the gain of the bass and treble.
Volume control
The SA300 has a knob on the front panel to adjust the volume level. This is directly linked to a JRC NJW1194 chip providing low noise and low distortion.
Product typeAmplifier
Inputs1x Micro USB
1x Stereo RCA
Bluetooth 5.0
OutputsSpeaker terminal
Subwoofer output (RCA)
Power2x80W @ 4Ω
2x40W @ 8Ω
THD+N0.008%
SNR90dB
Channel separation88dB
DAC ChipALC4042
Consumption (medium volume)35W
Standby consumption< 0.5W
Dimensions70 x 188 x 73mm
Weight1.2kg
Power supplyInclued
OutputSubwoofer
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipInfineon MA12070
Power (W)80.0
Remote ControlYes
17 reviews
Petit mais puissant
Mon premier ampli intégré en classe D. Je venais d’un Pioneer A-109, le tout associé à des Eltax Monitor III.
L’ampli est branché au DAC du SMSL en USB sur mon PC (le câble fourni fait un peu cheap et surtout trop court : 1 mètre).
Côté musicalité, je n’ai pas constaté de différence flagrante par rapport au Pioneer : la restitution reste très bonne.
Points positifs : il ne chauffe pas, prend très peu de place et propose des réglages simples avec basses/aigus en mode Tone ou via des presets.
La télécommande fait le job, même s’il faut être bien en face de l’ampli pour qu’elle réagisse.
Seul vrai point négatif à mon goût : l’écran reste allumé en permanence + y'a pas de prise casque comme le AD-18
This review has been posted for SMSL SA300 Class D Amplifier USB Bluetooth 5.0 aptX Subwoofer MA12070 2x80W 4 Ohm 32bit 384kHz
Petit ampli classe D très sympa
Meilleur qu'un ad18, son mieux defini et une sonore moins étriquée.
Epaulé par un dac su-1, cela fait un système d'un bon rapport qualité prix.
Quick shiiping...5 stars sellers!!
Très content
Ravis par ce petit ampli, très efficace pour le prix. Aigues un peu fortes, je les baisse de 3 ou 4 dB dans le réglage, mais ça dépend des enceintes aussi (j'ai des klipsh).
Attention à la sortie sub, elle m'a semblé assez puissante pour une sortie non amplifiée par rapport à une sortie line d'ampli classique, donc monter très doucement le potard du caisson de basse amplifié !
Autre détail pas terrible c'est qu'il est tellement léger que suivant la disposition, tout les câbles à l'arrière peuvent soulever l'ampli vers l'arrière, ce qui le rend un peu ridicule...
Vraiment top
Pour ce prix, le rendu est de qualité. Il consomme très peu, très facile à utiliser malgré l'interface minimaliste. La qualité est au rendez-vous. Un bon système stéréo pour une pièce de 25m^2 en tout cas. Assez bonne restitution des basses et une bonne dynamique, même à faible niveau. Design soigné, livraison sans soucis, bref, tout est ok. Très surpris d'avoir un ampli de cette qualité à ce prix.
Although it has a compact format, this SMSL SA300 amplifier is able to deliver a comfortable 2x80W power at 4 ohm with high...
