SMSL VMV A1 PRO Amplifier Stereo / Mono
The SMSL VMV A1 Pro is an innovative amplifier that uses Gallium Nitride (GaN) transistors to deliver 2x160W of amplification at 4Ω. Its versatility also allows it to operate in pure mono mode, delivering an impressive 400W into 4Ω. Every component of the VMV A1 Pro has been meticulously selected to achieve exceptional audio performance, with an incredibly low harmonic distortion rate of 0.0003% and a signal-to-noise ratio of 109dB.
By buying this product you get 52 loyalty points
Reference : 20714
529,00 €tax incl.
440,83 € tax excl.
SMSL VMV A1 PRO Stereo / Mono Amplifier Infineon GaN 2x160W 4 Ohm / 1x400W 4 Ohm
SMSL VMV A1 PRO : Vue de face
SMSL VMV A1 Pro: High-efficiency amplification with GaN FET transistors
The VMV A1 Pro uses GaN FET transistors for its amplifier stage. These transistors offer significantly higher efficiency than traditional silicon transistors, minimising energy losses during switching and reducing heat generation. Furthermore, GaN transistors are distinguished by their extremely high switching speed, of the order of 1MHz. This increased speed has several notable advantages: it eliminates switching noise in the circuits, considerably reducing background noise, and it allows a much faster response time, adapting instantly to variations in power demand for greatly improved audio dynamics.
Comparaison de la vitesse de commutation entre des transistor MOSTFET et GaN
SMSL VMV A1 Pro: Optimised switched-mode power supply
The VMV A1 Pro incorporates a switched-mode power supply specially designed for demanding audio use. This power supply is capable of delivering considerable power while maintaining perfectly silent operation. For added safety, the VMV A1 Pro is equipped with overheating and overcurrent protection circuits.
SMSL VMV A1 PRO : Optimised switched-mode power supply
SMSL VMV A1 PRO : Gold-plated output terminals
SMSL VMV A1 Pro: Gold-plated output connectors for optimum transmission
The VMV A1 Pro's output connectors are gold-plated to protect them effectively against oxidation and corrosion, while ensuring excellent electrical conductivity for optimum, lossless audio signal transmission.
Overview of SMSL VMV A1 Pro
SMSL VMV A1 PRO : Overview
1Control knob
2Remote control receiver
3Power indicator light
4Screen
5Stereo line input (RCA)
6Mono XLR input
7Left speaker output (stereo)
8Right speaker output (stereo)
9IEC socket
Product typeIntegrated amplifier
Amplification componantInfineon GaN FET transistors
Inputs1x Stereo RCA input
1x Mono XLR input
OutputSpeaker terminal
Total harmonic distortion more noise (THD+N)0.003%
Signal-to-noise ratio (SNR)109dB
Dynamic range111dB
Channel separation75dB
Input sensitivityStereo: 680mV/22kΩ
Mono: 2100mV/22kΩ
Stereo output power2x160W @ 4Ω
2x85W @ 8Ω
Mono output power1x400W @ 4Ω
1x250W @ 8Ω
Volume control chipPGA2311
Power supply100-240V AC
Power consumptionStandby: < 0.5W
In use: 40W
Dimensions210 x 201.6 x 47.6mm
Weight1.56kg
CouleurBlack
Package1x SMSL VMV A1 Pro
1x Remote control
1x Power cord
SMSL VMV A1 PRO : Measurement
InputXLR
Channel2 (Stereo)
Channel1 (Mono)
ClassN/A
Amplifier chipTransistors
Power (W)400.0
Power (W)160.0
Remote ControlYes
SMSL VMV A1 PRO Amplifier Stereo / Mono Infineon GaN 2x160W 4 Ohm / 1x400W 4 Ohm
The SMSL VMV A1 Pro is an innovative amplifier that uses Gallium Nitride (GaN) transistors to deliver 2x160W of amplification at 4Ω. Its...
