By buying this product you get 36 loyalty points
The WiiM Vibelink Amp, marks the brand's first foray into non-connected integrated amplifiers, designed to pair with WiiM Mini, WiiM Pro, WiiM Pro+ and WiiM Ultra streamers. This audiophile amplifier integrates an ES9039Q2M DAC chip, a TI TPA3255 amplifier chip and six OPA1612 OPAs, all within a PFFB (Post-Filter Feedback) structure. It supports sampling rates up to PCM 24bit 192kHz via its Toslink optical and coaxial inputs, while delivering 2x200W output power at 4Ω. A notable advantage is bit-perfect playback, preserving the integrity of the signal from source to digital-to-analog conversion stage. A pure RCA analog input is also available, bypassing any ADC conversion for optimum fidelity of vinyl and CD sources. The Vibelink Amp benefits from advanced thermal management and a 12V trigger for a pleasant user experience. Affordable and high-performance, this WiiM amplifier is sure to win over audiophiles.
The Vibelink Amp's digital-to-analog conversion stage is based on an ESS ES9039Q2M chip, supporting sampling rates up to PCM 24bit 192kHz via optical and coaxial inputs. Amplification is provided by a TEXAS Instruments TI TPA3255 chip, renowned for its performance, and six OPA1612 AOPs, delivering up to 2x200W output power at 4Ω. This combination of premium components guarantees low distortion and noise over a wide dynamic range, for rich, detailed sound reproduction.
The Vibelink Amp incorporates a PFFB (Post-Filter Feedback) circuit that minimizes load dependency through constant dynamic adjustment. This reduces distortion and noise levels, ensuring optimum, stable sound quality, even with speakers of different impedances.
The Vibelink Amp's analog RCA input bypasses any analog-to-digital conversion (ADC), enabling authentic, audiophile sound reproduction that preserves the integrity of high-fidelity analog sources such as vinyl and CD. For digital sources, the Toslink optical and coaxial inputs offer bit-perfect playback up to 24bit 192kHz, guaranteeing lossless audio fidelity to the original source.
Despite its high amplification power, the WiiM Vibelink Amp maintains optimum operating temperature thanks to an advanced thermal management system. This cooling system includes a copper heat pipe and an aluminum radiator that ensure rapid heat transfer from the main components and efficient dissipation. PID control regulates temperature in real time for stable, long-lasting performance.
The WiiM Vibelink Amp is packed with additional features to enhance the user experience. It includes a 12V trigger via a 3.5mm jack connector, as well as an automatic sleep mode that switches the device off after 30 or 60 minutes of inactivity.
The Vibelink Amp is designed to integrate seamlessly with WiiM network players, whether via digital or analog connections, offering a consistent, high-performance audio solution.
1 | Power input |
2 | 12V jack 3.5mm trigger input |
3 | Optical Toslink input |
4 | Coaxial input |
5 | RCA input |
6 | Speaker terminals output |
Product type | Amplifier |
Amplification type | Class D |
DAC chip | ESS ES9039Q2M |
Amplification chip | TPA3255 |
OPA | 6x OPA1612 |
Circuit | PFFB |
Inputs | 1x Stereo RCA 1x Optical Toslink 1x Coaxial |
Output | Speaker terminals |
Supported sampling rates | PCM up to 24bit 192kHz |
Output noise | 2x100W @ 8Ω 2x 200W @ 4Ω |
SNR | 120dB |
THD | 0.0005% |
Frequency response | 20Hz-20kHz ±0.5dB |
Impedance | 3-8Ω |
Color | Gray |
Dimensions | 200 x 63 x 200mm |
Weight | 2.05kg |
Package | 1x WiiM Vibelink AMP 4x 4mm banana plug to bare wire adapter 1x Power cable |
Input | SPDIF |
Input | RCA |
Input | Optical |
Output | Speaker terminal |
Color | Gray |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 200.0 |
Remote Control | No |
