LHY AUDIO Digital Interface Module
This LHY Audio digital interface module converts a digital signal via various inputs into an I2S signal via an output on a PCB connector. It features an AKM AK4118 chip and a QCC5125 Bluetooth receiver chip. The AK4118 chip enables this module to accept 24bit 192kHz streams via its coaxial SPDIF, AES/EBU and Toslink optical inputs, while the QCC5125 Bluetooth 5.1 receiver chip enables it to receive high-resolution Bluetooth codecs: SBC, AAC, aptX, aptX Adaptive and aptX HD.
Reference : 18770
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 05-06-2026.
LHY AUDIO Digital Interface Module AK4118 SPDIF AES Bluetooth 5.1 to I2S 24bit 192kHz
Photo of AK4118 LHY AUDIO Digital Interface Module
This LHY Audio digital interface module converts a digital signal via various inputs into an I2S signal via an output on a PCB connector. It features an AKM AK4118 chip and a QCC5125 Bluetooth receiver chip. The AK4118 chip enables this module to accept 24bit 192kHz streams via its coaxial SPDIF, AES/EBU and Toslink optical inputs, while the QCC5125 Bluetooth 5.1 receiver chip enables it to receive high-resolution Bluetooth codecs: aptX, aptX Adaptive and aptX HD. The PCB also features a source selection button and soldering pads for an external button.
There is also a small OLED display showing information about the signal being processed, such as the input source, signal format and sampling rate. A pushbutton on this small screen also allows the input source to be changed. And a remote control is provided for convenient distance operation.
The LHY Audio AK4118 digital interface module is powered by 5V DC.
Overview of the LHY Audio AK4118 digital interface module
Overview of the AK4118 LHY AUDIO Digital Interface Module
1Soldering pads for external source selection knob
2Source selection button
3PCB connector for external screen
4PCB connector for 5V DC power supply
5I2S output on PCB connector
6AK4118 interface chip
7Qualcomm QCC5125 Bluetooth receiver chip
8Toslink optical input
9Bluetooth antenna
10SPDIF coaxial input
11Entrée AES/EBU
12OLED screen
13Source selection button
Dimensions of the LHY AUDIO digital interface module
Product typeDigital interface module
Inputs1x Coaxial SPDIF input
1x Toslink optical input
1x AES/EBU input
Bluetooth
OuputI2S via PCB connector
INterface chipAK4118
Bluetooth reception chipQCC5125
Supported sample rates24bit 192kHz
Supported Bluetooth codecsSBC, AAC, aptX, aptX Adaptative, aptX HD
Power supply5V DC
Dimensions100 x 100mm
Mounting holes920 x 565mm
Net weight80g
Package1x AK4118 LHY Audio digital interface module
1x OLED screen
1x Connection cable for OLED screen
InputAES/EBU
OutputI2S
Max sampling rate192kHz
Interface chipAK4118
This LHY Audio digital interface module converts a digital signal via various inputs into an I2S signal via an output on a PCB connector. It...
