VIABLUE T8 TRS 6.35mm Mono Jack Connector (Unit)
The 6.35mm jack connectors TS T8 from Viablue integrate 24K gold-plated contacts, allowing stable conductivity to be maintained while limiting oxidation over time, while the black aluminum body ensures strong mechanical rigidity, protecting the connection points during use.
Reference : 22217
31,00 €tax incl.
25,83 € tax excl.
Shipping date: 27-11-2026.
Viablue T8 TRS 6.35mm Mono Jack Connector Gold-Plated (Unit)
VIABLUE T8 TRS 6.35mm Mono Jack Connectors Gold-Plated (Pair)
The 6.35mm jack connector TS T8 from Viablue integrate 24K gold-plated contacts, allowing stable conductivity to be maintained while limiting oxidation over time, while the black aluminum body ensures strong mechanical rigidity, protecting the connection points during use. The solder assembly is carried out on fully detachable contacts, facilitating assembly and ensuring a direct electrical connection, while an M4 hex socket screw (1.5mm) securely holds the cable within the connector. The clamping system accommodates cables from Ø4mm to Ø9.5mm, with two diameter reducers allowing thinner cables down to Ø3mm to be used, thus ensuring centered retention and clean integration.
Technical specifications
Product type6.35mm TS mono jack connectors
Contact plating24k gold
Assembly typeSolder
Body materialAluminum
Min. cable diameterØ4mm
Max. cable diameterØ9.5mm
Body length34.5mm
Retention systemM4 hex socket screw (1.5mm)
Outer diameterØ13.5mm
PackagingSold individually
Max cable diameter (mm)9.5
Mounting typeTo weld
ConnecticMale
Contacts number2
VIABLUE T8 TRS 6.35mm Mono Jack Connector Gold Plated (Unit)
The 6.35mm jack connectors TS T8 from Viablue integrate 24K gold-plated contacts, allowing stable conductivity to be maintained while limiting...
