JANTZEN AUDIO IRON CORE COIL DISCS 000-5587 4N Copper Wire Somaloy Core Coil 20AWG 0.68mH
High-purity copper wire wound around a Somaloy core. It offers high inductance while remaining very economical. The continued resistance value - extremely low - does not alter the damping factor and the loss of efficiency.
Reference : 21972
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 17-11-2026.
low bass audio permite copper coil medium Jantzen audiophile passive filtering
Jantzen Audio Iron Core Coil Discs 000-55874N Copper Wire Somaloy Core Coil 20AWG 0.68mH
High-purity copper wire wound around a Somaloy core. It offers high inductance while remaining very economical. The continued resistance value - extremely low - does not alter the damping factor and the loss of efficiency. Somaloy material allows for a lesser filtering delay than that of ferrite cores coils while providing greater power.
This type of coil is generally popular for setting up crossover on bass and midrange frequencies. The holding power is determined by the size of the core and the thickness of the copper wire. The thicker the core and cable, the greater the overall power.  Thus, this type of copper  coil is among the most versatile for audio.
TypeSomaloy core coil
MaterialCopper high purity 4N / Core Somaloy
Inductance (mH)0.68mH (+/- 3%)
DRC (Ohms)0.2000 Ohm
Cable (mm)0.80mm
AWG20AWG
Weight (kg)0.328kg
Diameter24mm
Height38mm
Inductance (mh)0.68
High-purity copper wire wound around a Somaloy core. It offers high inductance while remaining very economical. The continued resistance value -...
