The Jantzen Audio Superior Z-Cap range consists of high end non-polarized capacitors, designed specifically for audio to enable your audio system to reproduce every nuance and every detail of the signal, while maintaining unrivalled naturalness and realism.
They are particularly recommended for use as high-end tweeter capacitors or as coupling capacitors in amplifiers. All Jantzen Audio Z-Cap capacitors have a nitrogen filling to increase the amount of foil per capacitor, while eliminating the risk of evaporation that can occur in capacitors using oil or other dielectric fluids.
Product type | Capacitor |
Dielectric | Azote |
Foil material | Double sheets of polypropylene metallised with aluminium and zinc particles |
Contacts material | PC-OCC copper |
Capacitance | 0.33µF |
DC voltage | 1200V |
AC voltage | 600V |
Tolerance | ±2% |
Operating temperature | -30°C / +105°C |
Non-inductive design | - |
Polarisation | Non-polarized |
Dimensions & Weight | |
Diameter | 26mm |
Length | 45mm |
Weight | 29g |
Tolerance (%) | 2 |
Capacitor capacitance (µF) | 0.33 |
Rated voltage (V) | 1200 |
Capacitor type | Film capacitor |
Capacitor format | Axial |
