DAYTON AUDIO MX5-22 DVC Subwoofer Speaker 50W 2+2 Ohms 84dB 30Hz–1000Hz 13.3cm
The Dayton Audio MX5-22 is a compact 5.25-inch dual voice coil (DVC) subwoofer driver designed to deliver deep and dynamic bass despite its compact size.
Reference : 21988
59,57 €tax incl.
49,64 € tax excl.
Dayton Audio MX5-22 Subwoofer Driver DVC 50W 2+2 Ohm 84dB 30Hz-1000Hz Ø13.3cm
DAYTON AUDIO MX5-22
The Dayton Audio MX5-22 is a compact 5.25-inch dual voice coil (DVC) subwoofer driver designed to deliver deep and dynamic bass despite its compact size. Part of the Dayton Audio Max-X series, it features a long-excursion architecture combined with a high-energy motor to provide impressive performance both in home HiFi and car audio applications. Its dual 2Ω voice coil system allows multiple wiring configurations to optimize compatibility with a wide range of amplifiers. Capable of handling up to 50W RMS and 100W peak power, the MX5-22 benefits from a low resonance frequency of 45Hz and a large linear excursion of 9.3mm Xmax, enabling it to produce powerful, precise, and controlled bass in compact sealed or bass-reflex enclosures.
The MX5-22 is built with a particularly refined design featuring a treated paper cone, a large concave dust cap fully covering the cone to improve mechanical rigidity, and a reinforced rubber surround optimized for high excursion. Its 4-layer CCA voice coil mounted on a ventilated aluminum former improves heat dissipation, while its ventilated motor with multiple vents reduces thermal compression during high-power operation. Dayton Audio also integrates an aluminum demodulation ring to stabilize inductance and significantly reduce distortion, resulting in a cleaner and more linear response throughout the driver's excursion range.
With a frequency response from 30Hz to 1000Hz, a sensitivity of 84.3dB, a force factor of 8T·m, and a reinforced steel frame specially designed for long excursion, the MX5-22 offers an excellent performance-to-size ratio. Its 6-inch outer diameter, shallow 89mm mounting depth, and 4.75-inch cutout diameter make it easy to integrate into many compact DIY audio projects requiring powerful and controlled bass performance.
Measurements of the DAYTON AUDIO MX5-22
Dayton Audio MX5-22: Long-Excursion Architecture and Powerful Bass
The MX5-22 was developed to deliver remarkable performance in an extremely compact format.
Thanks to its long-excursion motor, low resonance frequency, and 9.3mm Xmax linear excursion, it is capable of producing deep and dynamic bass despite its compact 5.25-inch diameter.
This design makes it ideal for compact HiFi speakers, miniature subwoofers, or car audio installations requiring powerful bass in limited space.
DAYTON AUDIO MX5-22: Long-Excursion Architecture and Powerful Bass
DAYTON AUDIO MX5-22: Optimized Cooling and High Power Handling
Dayton Audio MX5-22: Optimized Cooling and High Power Handling
The MX5-22 features a highly optimized ventilation architecture designed to maintain stable performance even during demanding use.
Its 4-layer CCA voice coil is mounted on a ventilated aluminum former that efficiently improves heat dissipation. Additional vents positioned around the spider as well as a ventilated pole piece increase airflow within the motor structure to reduce heat buildup and minimize thermal compression.
This design allows the driver to handle up to 50W RMS while maintaining excellent operating stability.
Dayton Audio MX5-22: Dual 2Ω Voice Coil and Distortion Reduction
The MX5-22 integrates two 2Ω voice coils offering great wiring flexibility to easily match impedance with different amplifiers.
Its high-energy motor also benefits from an aluminum demodulation ring designed to stabilize inductance during voice coil movement. This technology reduces distortion, improves linearity, and ensures cleaner, more precise, and better-controlled bass even at high sound levels.
The entire assembly is mounted in a robust reinforced steel frame providing the mechanical clearance required for high excursion while ensuring excellent structural rigidity.
DAYTON AUDIO MX5-22: Dual 2Ω Voice Coil and Distortion Reduction
Technical Specifications
Driver typeSubwoofer
Nominal diameter5-1/4" 13.3cm
Power handlingRMS: 50W
Max: 100W
Impedance4Ω
Frequency response30-1000Hz
Sensitivity84.3dB 2.83V/1m
Voice coil diameterØ31.75mm (1.25")
Weight3.9kg
Thiele-Small Parameters
Resonance frequency (Fs)45Hz
DC resistance (Re)4.3Ω
Voice coil inductance (Le)1.1mH
Mechanical Q factor (Qms)3.02
Electrical Q factor (Qes)0.5
Total Q factor (Qts)0.43
Equivalent air compliance volume (Vas)0.172ft³
Mechanical compliance of suspension (Cms)0.48mm/N
Force factor (BL)8T·m
Total moving mass including air load (Mms)26g
Maximum linear excursion (Xmax)9.3mm
Cone surface area (Sd)84.4cm²
Materials
ConePaper
SurroundRubber
Voice coil wireCCA
Voice coil formerAluminum
BasketSteel
MagnetFerrite
Mounting Information
Overall outer diameterØ152.4mm
Cutout diameterØ120.65mm
Depth88.9mm
Number of mounting holes8
Recommended Enclosure Size
Sealed volume0.3ft³
Sealed F384Hz
Ported volume0.35ft³
Ported F333Hz
Packaging1x Dayton Audio MX5-22
Speaker Power (W RMS)50.0
Speaker TypeSubwoofer
Impedance (Ω)2+2
Loudspeaker diameter (mm)133.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)84.0
Max Linear Excursion (Xmax) (mm)9.3
Lowest frequency (Hz)30
Highest frequency (Hz)1000
The Dayton Audio MX5-22 is a compact 5.25-inch dual voice coil (DVC) subwoofer driver designed to deliver deep and dynamic bass despite its compact...
