DAYTON AUDIO MX6-22 Speaker Driver DVC Subwoofer
The DAYTON AUDIO MX6-22 is a 6.5-inch (16.5cm) subwoofer driver designed to deliver remarkable performance in compact enclosures, whether for home HiFi, car audio, or custom installations.
Reference : 22101
79,90 €tax incl.
66,58 € tax excl.
Dayton Audio MX6-22 Speaker Driver DVC Subwoofer 70W 2x2 Ohms 83dB 25Hz-1000Hz Ø16.5cm
DAYTON AUDIO MX6-22
The Dayton Audio MX6-22 is a 6.5-inch (16.5cm) subwoofer driver designed to deliver remarkable performance in compact enclosures, whether for home HiFi, car audio, or custom installations. Featuring a dual voice coil architecture rated at 2Ω + 2Ω, it offers great wiring flexibility to suit a wide range of amplifiers. Its long-excursion motor combined with a low 30Hz resonant frequency enables it to produce powerful, deep bass despite its compact size. Its paper cone is reinforced by a full-surface concave dust cap, while the high-excursion rubber surround ensures long-term reliability. The MX6-22 incorporates a 38mm four-layer copper voice coil wound on a vented aluminum former, a ferrite magnet motor, and an aluminum shorting sleeve designed to reduce inductance variations and distortion. Its precision-stamped steel frame features a fully vented architecture with a pole vent and gap vents to optimize cooling. With a power handling capability of 70W RMS (140W max), a sensitivity of 83dB (2.83V/1m), a maximum linear excursion (Xmax) of 12mm, and a frequency response extending from 20Hz to 1000Hz, the MX6-22 is an ideal solution for building compact high-performance subwoofer enclosures.
DAYTON AUDIO MX6-22 Measurement
Dayton Audio MX6-22: Long Excursion and Powerful Bass in a Compact Format
Despite its modest 6.5" diameter, the MX6-22 is capable of reproducing deep bass thanks to its long-throw motor and substantial 12mm linear excursion. Its 30Hz resonant frequency, high 12.3Tm force factor, and low Qts of 0.33 allow it to perform efficiently in small sealed or bass-reflex enclosures. Its dual 2Ω + 2Ω voice coils provide multiple wiring configurations to optimize compatibility with a wide range of amplifiers.
DAYTON AUDIO MX6-22: Long Excursion and Powerful Bass in a Compact Format
DAYTON AUDIO MX6-22: Rugged Design and Optimized Cooling
Dayton Audio MX6-22: Rugged Design and Optimized Cooling
The Dayton Audio MX6-22 benefits from a particularly refined mechanical design. Its paper cone is paired with an inverted dust cap covering the entire diaphragm to improve rigidity while giving it a modern appearance. The reinforced rubber surround ensures durable operation under high excursion. The four-layer copper voice coil wound on a vented aluminum former, combined with vents around the spider, the central pole vent, and the air-gap openings, promotes excellent heat dissipation and limits power compression during prolonged use.
Dayton Audio MX6-22: Reduced Distortion and Accurate Bass Reproduction
The magnetic motor of the MX6-22 has been engineered to maintain symmetrical driving force throughout the cone travel, ensuring excellent linearity even at high output levels. An integrated aluminum shorting sleeve stabilizes voice coil inductance and reduces distortion across the entire frequency range. This design contributes to precise, dynamic, and tightly controlled bass while facilitating seamless integration with main speakers in HiFi, home theater, or automotive audio systems.
DAYTON AUDIO MX6-22: Reduced Distortion and Accurate Bass Reproduction
Technical Specifications
Driver TypeSubwoofer
Nominal Diameter16.5cm (6-1/2")
Power HandlingRMS: 70W
Max: 140W
Impedance2 + 2 Ohms
Frequency Response20-1000Hz
Sensitivity83dB 2.83V/1m
Voice Coil Diameter38mm
Weight3.2kg
Thiele-Small Parameters
Resonant Frequency (Fs)30Hz
DC Resistance (Re)4.7Ω
Voice Coil Inductance (Le)< 1.5mH
Mechanical Q Factor (Qms)2.99
Electrical Q Factor (Qes)0.37
Total Q Factor (Qts)0.33
Equivalent Compliance Volume (Vas)0.353ft³
Mechanical Compliance (Cms)0.44mm/N
Force Factor (BL)12.3T·m
Moving Mass Including Air Load (Mms)63.8g
Maximum Linear Excursion (Xmax)12mm
Cone Area (Sd)126.3cm²
Materials
ConeCoated Paper
SurroundRubber
Voice Coil WireCopper
Voice Coil FormerAluminum
BasketSteel
MagnetFerrite
Mounting Information
Overall Outside Diameter18.1cm (7.125")
Cutout Diameter14.2cm (5.6")
Depth10.2cm (4")
Number of Mounting Holes8
Recommended Enclosure Size
Sealed Volume0.25ft³
Sealed F376Hz
Vented Volume0.4ft³
Vented F329Hz
Package Contents1x Dayton Audio MX6-22
Speaker Power (W RMS)70.0
Speaker TypeSubwoofer
Impedance (Ω)2+2
Loudspeaker diameter (mm)165.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)83.0
Max Linear Excursion (Xmax) (mm)12.0
Lowest frequency (Hz)10
Highest frequency (Hz)1000
DAYTON AUDIO MX6-22 Speaker Driver DVC Subwoofer 70W 2x2 Ohms 83dB 25Hz-1000Hz Ø16.5cm
The DAYTON AUDIO MX6-22 is a 6.5-inch (16.5cm) subwoofer driver designed to deliver remarkable performance in compact enclosures, whether for home...
