DAYTON AUDIO SD315A-88 Subwoofer Speaker
The Dayton Audio SD315A-88 is a 30.48cm (12") subwoofer speaker designed for bass systems requiring significant extension in the lower part of the spectrum, while maintaining a ratio between power handling and integration cost suited to DIY projects. Its dual voice coil of 8 Ω per coil, presented here with parallel wiring to obtain a 4 Ω load, allows various amplification configurations and facilitates its adaptation to sealed or bass-reflex enclosures.
Reference : 22525
119,90 €tax incl.
99,92 € tax excl.
Grantie 5 ans
DAYTON AUDIO SD315A-88 Subwoofer Speaker 120W 93.75dB 4 Ohm 24Hz-2kHz
DAYTON AUDIO SD315A-88: Front view
The Dayton Audio SD315A-88 is a 30.48cm (12") subwoofer speaker designed for bass systems requiring significant extension in the lower part of the spectrum, while maintaining a ratio between power handling and integration cost suited to DIY projects. Its dual voice coil of 8 Ω per coil, presented here with parallel wiring to obtain a 4 Ω load, allows various amplification configurations and facilitates its adaptation to sealed or bass-reflex enclosures. With a power handling of 120 W RMS, reaching up to 240 W maximum, a frequency response of 24 to 2,000 Hz and a sensitivity of 93.75 dB at 2.83 V/1 m, it delivers a high bass level while retaining usable reproduction in the first octave.
Its poly-treated paper cone, combined with a long-life rubber surround and a long-excursion design, helps maintain mechanical control during large displacements, while the vented pole pieces and the raised back plate promote thermal dissipation of the motor. This architecture is extended by a basket without an added gasket, whose compact finish simplifies installation and preserves a consistent appearance once the speaker is mounted. Thanks to its dual voice coil, its usable excursion and its compatibility with sealed as well as ported loads, the SD315A-88 is suitable for building economical enclosures, dedicated bass systems or for replacing a subwoofer speaker in an existing installation.
DAYTON AUDIO SD315A-88: Dimensions and measurements
Technical specifications
Product typeSubwoofer
Impedance4Ω
Sensitivity93.75dB 2.83V/1m
Frequency response24Hz-2kHz
Voice coil diameter5.08cm (2")
Nominal diameter30.48cm (12")
PowerRMS: 120W
MAX: 240W
Thiele-Small parameters
Resonance frequency (Fs)24.2Hz
Cone surface area (Sd)522.8cm²
Voice coil inductance (LE)1.5mH
DC resistance (Re)3.1Ω
Mechanical quality coefficient (Qms)3.54
Electromagnetic quality coefficient (Qes)0.37
Total quality coefficient (Qts)0.33
Force factor (BL)11.86T·m
Total moving mass + air load on cone (Mms)109.2g
Mechanical compliance of suspension (Cms)0.4mm/N
Compliance equivalent volume (Vas)5.36ft³
Max linear excursion (Xmax)7mm
Mounting informations
Cutout diameter27.20cm (10.71")
Depth13cm (5.12")
Number of mounting holes5
Total outer diameter31.39cm (12.36")
Materials
DiaphragmTreated paper
MagnetFerrite
FrameSteel
SurroundRubber
Voice coil wireCopper
Recommended Enclosure Volume
Sealed Volume31.14L (1.1ft³)
Sealed F358Hz
Vented Volume65.12L (2.3ft³)
Vented F334Hz
Weight4.7kg
PackageSold individually
Speaker Power (W RMS)120.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)304.8
Diaphragm typePaper
Efficiency / Sensitivity (dB)93.75
Max Linear Excursion (Xmax) (mm)7.0
Lowest frequency (Hz)24
Highest frequency (Hz)2000
The Dayton Audio SD315A-88 is a 30.48cm (12") subwoofer speaker designed for bass systems requiring significant extension in the lower part of...
