DAYTON AUDIO SDA315A-88 Speaker Driver Subwoofer
The Dayton Audio SD315A-88 is a 30.48cm (12") woofer with dual 8 ohm voice coils, designed for subwoofer systems seeking solid extension in the low end with a power handling of 120 W RMS and 240 W maximum.
Reference : 22421
130,00 €tax incl.
108,33 € tax excl.
DAYTON AUDIO SDA315A-88 Subwoofer Speaker Driver 120W 8+8 Ohm 93.75dB 24Hz-2000Hz
DAYTON AUDIO SDA315A-88: Front view
Its polypropylene-coated paper cone, combined with a long-life rubber surround, high excursion and long-throw construction, allows a stable reproduction in the first octave, in sealed as well as bass-reflex enclosures. The vented pole pieces and the raised back plate improve cooling of the motor, while the two voice coils allow adapting the wiring and overall impedance according to the chosen configuration. Its gasketless front favors a clean integration, suited to affordable bass builds requiring substantial air displacement.
DAYTON AUDIO SDA315A-88: Dimensions and measurements
Product typeSubwoofer
Impedance4Ω (8+8Ω)
Sensitivity93.75dB 2.83V/1m
Frequency response24Hz-2000Hz
Voice coil diameter5.08cm (2")
Nominal diameter30.48cm (12")
PowerRMS: 120W
MAX: 240W
Thiele-Small parameters
Resonance frequency (Fs)24.2Hz
Cone surface area (Sd)522.8cm²
Voice coil inductance (LE)1.5mH
DC resistance (Re)3.1Ω
Mechanical quality coefficient (Qms)3.54
Electromagnetic quality coefficient (Qes)0.37
Total quality coefficient (Qts)0.33
Force factor (BL)11.86T·m
Total moving mass + air load on the cone (Mms)109.2g
Mechanical compliance of suspension (Cms)0.4mm/N
Compliance equivalent volume (Vas)5.36ft³
Max linear excursion (Xmax)7mm
Mounting informations
Cutout diameter27.20cm (10.71")
Depth13cm (5.12")
Number of mounting holes5
Total external diameter31.39cm (12.36")
Materials
DiaphragmTreated paper
MagnetFerrite
FrameSteel
SurroundRubber
Voice coil wireCopper
Weight4.7kg
PackageSold individually
Speaker Power (W RMS)120.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)304.8
Diaphragm typePaper
Efficiency / Sensitivity (dB)93.75
Max Linear Excursion (Xmax) (mm)7.0
Lowest frequency (Hz)24
Highest frequency (Hz)2000
DAYTON AUDIO SDA315A-88 Speaker Driver Subwoofer 120W 8+8 Ohm 93.75dB 24Hz-2000Hz
The Dayton Audio SD315A-88 is a 30.48cm (12") woofer with dual 8 ohm voice coils, designed for subwoofer systems seeking solid extension in...
